bad battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by itwrx, Nov 22, 2013.
  1. itwrx
    itwrx New Member
    Park City, Utah
    Would the error code show as a red triangle on the dash or just as a code a OBDII reader would show?
  2. vskid3
    vskid3 Active Member
    773
    228
    Scangauge is good, but kind of outdated. A cheap bluetooth ELM327 scanner and the Torque app for Android devices will be able to show you all the voltages at once, not just 4. I don't have one, but I believe a mini VCI scanner with Techstream for PC will do the same.
  3. itwrx
    itwrx New Member
    Park City, Utah
    know of any good options for iOS or mac?
  4. Mendel Leisk
    42,386
    If I hook up a digital multi-meter when the car is off, I get readings between 12.5 and 12.7, depending on temp, recent use and I'm not sure what all.
    I'm not sure if "acc mode" would be different, what it entails.
  5. vskid3
    773
    228
  6. Patrick Wong
    18,214
    6,531
    Actually you should measure the module voltages while the lights are on so that the battery is under load while you are doing the measurements. You've already determined that when the battery has no load, the battery module voltages are all good. Obviously this means the battery case has to be open during the testing.
  7. itwrx
    itwrx New Member
    Park City, Utah
    What is the inch pound setting I should use on each cell terminal?
  8. Patrick Wong
    18,214
    6,531
    Your question presupposes the need to disconnect the module wiring which implies you will find a bad module. I think that this is not necessarily the case.
    However, the answer is 48 in.-lb.
  9. itwrx
    itwrx New Member
    Park City, Utah
    Thanks. I had already undone all the cells assuming I would find a dead one. Oh well lesson learned. At least I got to clean all the brass contacts.
    tomcornell likes this.
