Bad C ac Compressor.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Randy Gilliam, Jun 25, 2012.
  1. Randy Gilliam
    Randy Gilliam New Member
    2011 ,89,000 Miles AC Comp. Out, $3009.00 To Repair at Universal Toyota In Sa Tex. Any Ideas?, 104 degrees Today.Randy G.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,132
    6,982
    Texas Hill Country
    I would call Alamo Toyota or North Park. I have my doubts about Universal. Then I would consider finding a used part and have someone put it in. This one 2011 TOYOTA PRIUS Compressor | eBay is $500 with only 4000 miles on the car.
    You could check with this shop on San Pedro. Toyota Prius repairs | San Antonio, Texas
    Finally you could pickup this local ebay seller's Prius Repair Manual software and determine how big a job it really is. I am sure lots of mechanics could do the job with good instructions. TOYOTA PRIUS 2010 2011 SERVICE & REPAIR MANUAL SOFTWARE | eBay
    Let me know what you find out.
  3. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    First time making a post since the format change & somehow all I got was a quote of the above posts (which I deleted).
    Ken (in Bolton, Ct
  4. Ct. Ken V
    535
    57
    Bolton,CT
    Regardless of who does the job, be sure they use the special Toyota lubricant (that doesn't conduct electricity in the electric compressor) when re-charging the system with the refrigerant.
    Ken (in Bolton,Ct)
  5. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Was the AC serviced recently? Just seems odd it would die after only a year or so.
  6. Ct. Ken V
    535
    57
    Bolton,CT
    I agree about the premature failure, but that's a lot of miles for a one year old car & I assume Texas has year round temperatures that pretty much require full time use of the A/C system.
    Ken (in Bolton, Ct)
  7. lech auto air conditionin
    830
    606
    261
    san francisco
    $3000, sounds about right, here in San Francisco. it is too soon for a compressor burn out, was this car in a front end hit and a body shop replaced or removed the a/c condenser to do body work. This is were I get most of my pruis compressor burn outs from. Body shops make A/C tech a lot of money from their mess ups.
    After a burn out if there is metal in there system, you replace the condenser, the expansion valve ( 7 hours labor to remove the dash to get to the expansion valve), Flush out all the lines and hoses, replace or flush out the evaporator depending if you find metal in the EVAP.
    If you buy a used compressor only use the ND-11 oil about $200 for a 8oz can.
    ? Was the A/C slowly over time getting warmer( not working so well ) . ??
    Look at the photos on my page of burnout compressors and metal in the condenser. I show a photo of the filter and dryer sock removed from the condenser. WARRING DO NOT!!!!! BUY A CHEAP NON-OE CONDENSER WITH LESS COOLING TUBE AND LESS COOLING FINS!!!!!!!......
    Some times around here the Toyota dealer just replaces the compressor after a burn out, it will some times work long enough to get the customer out of warranty$$$$$$$ then when you come back they get to charge you the big bucks$$$$$$$$$.....
    cwerdna likes this.
  8. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the proper forum
