Bad cell in battery
Discussion in 'Generation 1 Prius Discussion' started by nightmare66, Jan 5, 2019.
  1. nightmare66
    nightmare66 Junior Member
    24
    Kentucky
    2001 Prius
    I
    Code scanner says I have a bad cell on row 13, do i just replace it with one from ebay? I have a bluedriver multimeter is that all i need to test it and the other cells? what do i need to look for?
  2. bwilson4web
    16,552
    It is a little more complicated:
    1. Needs to match the Ahr capacity of the other modules
    2. Needs to be charged to the same level as the other modules
    3. Adjacent modules need to be checked to see if they are weak
    4. First generation modules are weak
    People have done it but the recommended practice is to use Gen-2 or later modules to replace all of them. However, there is a 3d party solution that uses new, "D" cells which looks really good. There would be a challenge with going from 28/2 = 14 modules to 38/2 = 19 modules.
    Raytheeagle likes this.
  3. nightmare66
    24
    Kentucky
    2001 Prius
    I
    Can it be charged with a battery charger while checking with a volt meter?
    Who sells reliable modules? i'm looking for a trusted source for used modules.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    @jeff652 and @TMR-JWAP sell modules.
    They are members here and test them before using.
    Might be worth starting a conversation with them and see what they have.
  5. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    The 3rd party solution is not for Gen 1 Prius, It looks like you may be able to get a new Toyota battery for about $2000 after returning the core.
    2001 Toyota Prius Parts - metrotoyotapartsnow.com
  7. nightmare66
    24
    Kentucky
    2001 Prius
    I
    anyone tried these?
    padroo likes this.
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    Ummm...
    Did you forget something? Try what?
  9. Eric Baker
    Eric Baker Junior Member
    Blacksburg, VA
    2014 Prius v wagon
    I just put a set of 10 of these below in my gen1 pack. I really only needed three but replaced all the lowest measuring modules. I cycled all the cells at 2A discharge down to 6.0V and fully charged at 3A using a Turnigy Reaktor charger/discharger. I ranked by discharge capacity and matched high and low pairs.
    The modules apparently came out of a bus and were in a very low state of charge when I received them. Cycling brought them back after 2-deep discharge/charge sessions with a few days rest between.
    Search Ebay: gen 1.5 prius modules (I can't post link?)
    Overall I am happy with the modules.
  10. Eric Baker
    Blacksburg, VA
    2014 Prius v wagon
