Bad fuel pump or electrical issue?
Discussion in 'Gen 2 Prius Main Forum' started by 3Prii, Jun 14, 2020.
  1. 3Prii
    3Prii Junior Member
    Tyler, TX
    Was driving and plugged in my phone to the charger in my Prius and heard a loud pop. All the warning light came on and the car slowed to a stop. Had a mechanic come by and check the codes and got P3193 (fuel ran out) and P3190 (engine failed to start). I have half a tank of gas so that’s definitely not the issue. Mechanic said there is no fuel pressure and that I need a new pump and tank assembly. I’m just concerned about the loud pop and there’s something electrical going on instead. He checked the fuses and swapped the fuel pump cassette and found nothing wrong with those.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Was the pop from the front under the hood, or towards the rear of the vehicle?
    The fuel pump is located inside the gas tank, does this sound correct?
    Here is the workup for DTC P3190 and P3193 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/2054m/cip3190a.pdf
    #2 SFO, Jun 14, 2020
  3. 3Prii
    3Prii Junior Member
    Tyler, TX
  4. PriusCamper
    PriusCamper Senior Member
    13,459
    5,430
    Pacific Northwest, USA
    I'd be suspicious of an error code pointing to the fuel pump... There's issues with standard automotive code readers mis-reading the error code because they aren't programmed for specifc Prius codes and subcodes. Dr. Prius App via an obd2 bluettoth reader is the way to go: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    You said you plugged your phone into a charger? Was that charger plugged into cigarette lighter? If that circuit is still functional I"d be focused on an aging 12v battery being the source of your problem.
  5. 3Prii
    3Prii Junior Member
    Tyler, TX
    He used Techstream to read the codes so I’m hoping there’s no issue with mis-reading. Also, the 12v was replaced in March and the voltage was 12.3.
  6. PriusCamper
    13,459
    5,430
    12.3v is a bad battery! Hope you have a warranty... I'm willing to bet the battery you bought is an Optima. They have zero quality control...
  7. 3Prii
    3Prii Junior Member
    Tyler, TX
    Sorry I should have clarified, 12.3 with the car powered off 14.4 with it on and it’s an OEM battery.
  8. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Does the vehicle still run?
    Have you inspected or cleaned the butterfly valve which is located in the throttle body, use a toothbrush dipped in vodka or rubbing alcohol.
    Since you already have the most current DTCs recorded, start going step by step with the above work up.
    If there is a step you cannot perform, just skip and go to the next, you might notice that something is off.
    PriusCamper and Raytheeagle like this.
  9. 3Prii
    3Prii Junior Member
    Tyler, TX
    Ok we figured out the problem! The car was actually out of gas despite showing half a tank...time to recalibrate the fuel gauge.
    SFO likes this.
