Bad Gas mileage - 12v battery solution
Discussion in 'Gen 3 Prius Fuel Economy' started by karl.d, Jan 15, 2019.
  1. EricWagner
    EricWagner New Member
    Washington State
    NewI have been dealing with mileage dropping over the last 4 months. At 100k, I decided to do some maintenance and with the help of NutzaboutBolts, I went ahead and performed:
    1) transmission oil change
    2)engine oil change
    3) spark plug replacement
    4) install oil catch can
    5) removeand clean egr valve amd tube
    6) remove and clean intake manifold
    7) remove and clean throttle body
    8) replaced O2 sensor
    9) replaced MAF sensor
    All of this was proactive maintenance. I had zero issues and no check engine lights.
    After all of this, I experienced a slow decrease in MPG- from normal of 50-54 to 44-47.
    No matter what I did, light on the accelerator, tires at 40psi, premium fuel, ECO Mode, and overall conscious driving g habits, I couldn't get this thing back to "normal."
    Today I decided to bite the bullet and buy a new 12v battery. I had no reason to suspect this was the issue because I purchased this Prius used 2 years ago and when I looked at the battery 2 months ago, the sticker on it said 8/17. I figured the battery is 2 years old- still good right?
    Last week, while sitting in my car watching my in-dash dvd player (which came with the vehicle) a message appeared that I had not seen in the past. I typically sit in my car for an hour or a little more, 3 days a week while my daughter has soccer practice. I'll usually pop a dvd in and watch it.
    The message said something to the effect- shutting down to conserve battery. I am always in Accessory Mode when watching the dvd.
    Today I swapped out the 12v battery with a new yellow top Optima at a cost of approximately $230 dollars at local AutoZone. Drove it right after on the highway for about 10 miles and I'm up over 54!!!
    Hopefully, problem solved
    bisco and Mendel Leisk like this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Stay in Ready to consume electricity, it is much safer.
    RMB and Mendel Leisk like this.
  3. Mendel Leisk
    42,352
    In other words, with the car fully "on", the engine cycling on/off as necessary. Still, doing that won't help the mpg: just switch it right off, bring along a Walkman or similar? Or a book?
    RMB likes this.
  4. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    Or cellphone and unlimited data plan LOL
  5. bisco
    52,861
    well done! (y) how many miles on her?
  6. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    (silly question, admin delete)
    #26 andreimontreal, Dec 19, 2019
  7. andreimontreal
    390
    118
    40
    Montreal
    Toyota also told me my battery is in great shape. My mpg not so amazing too. Not sure which battery they were referring to; I always assumed it was the hybrid - now I'm starting to think it was the 12V, not that they were spot on or anything. They gave me this small piece of paper with 4/5 dots full kinda like a tiny receipt.
    Karl thanks for stopping to write details such as the remote not working and whatnot. From what I read around here I might have the same issue.
  8. bisco
    52,861
    that is definitely a 12v report. is it original?
  9. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    What type of tires do you have on the car now?
    I will never get the cooper tires again. I'm going back to the Continentals. It's just too hard to get
    the MPG's up. I've lost 5 mpg with the cooper tires.
    For "ME", tire pressure only gained me possibly 1 mpg.
    I seem to remember you asking about tires, did you get new ones yet? If so, which ones did you get?
    That could be where you are loosing the mpg's.
  10. andreimontreal
    390
    118
    40
    Montreal
    I got 4 set of Continental Wintercontact SI Plus about a month ago.
  11. ASRDogman
    8,066
    4,089
    Winter tires... okay. From my understanding of what others have said on Prius Chat, you'll loose the mpg's
    with winter tires. I guess it's how they are designed for the snow. You may have to live with them until summer.
  12. andreimontreal
    390
    118
    40
    Montreal
    Maybe. Time will tell. Gonna check that battery for sure.
    ASRDogman likes this.
  13. ASRDogman
    8,066
    4,089
    Yep, doesn't hurt to check the battery. Check everything and get everything repaired and up to date.
    Then you eliminate each item and can narrow things down to find a cause to a problem.
  14. Mendel Leisk
    42,352
    I'm getting better mpg on my 9 year old 15" X-Ice, than my new 17" Primacies...:cry:
    I'm sure it'll level out in a year or two, but just sayin'.
    #34 Mendel Leisk, Dec 19, 2019
  15. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    I think the 17” wheel is havier than the 15” - so not only the tyre model, but the wheel size also counts.
  16. Mendel Leisk
    42,352
    Yeah definitely, something like 24 pounds vs 16~17? And yeah 17" tires are heavier too. I can feel the difference every time I swap them.
    Attila Fekete likes this.
  17. Attila Fekete
    164
    59
    Budapest, Hungary
    I have my summer tyres on 17” and the winters on 16” - from Prius gen 2, 7 kg / ~15 lbs without the tyre. Summer ones are stored on my attic, I can feel your pain.
    #37 Attila Fekete, Dec 24, 2019
  18. Mendel Leisk
    42,352
    I've found a lifting technique that's easy, and easy on the back:
    Bring the wheel/tire up close, oriented roughly correct. Sit on the floor facing it, hook your toes under the wheel at around 5 and 7 o'clock. Lift the wheel with your toes while steadying and guiding it with your hands, onto the lugs. Helps to have good light, so you can see the studs through the wheel holes, line them up.
    StarCaller and Ed Beaty like this.
  19. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    my technique since decades / (y)
  20. Nano
    Nano New Member
    London Uk
    ----UK----
    Thanks for sharing Karl.
    I had a very similar experience. The car had good imperial mileage 56mpg but sometimes the doors weren't unlocked after I pressed the remote and I had to try it a few times.
    Then a week after a 300 miles drive, my car wouldn't start and I had to jump start it.
    After that the remote never failed again, but the mpg I get now is around 38mpg.
    I will definitely take it to a mechanic for them to replace the 12v battery, didn't even realise it was this but it will most likely be the culprit of the extra fuel consumption.
