Bad HV Battery? Or bad fan?
Discussion in 'Gen 2 Prius Technical Discussion' started by koukilights, Jul 6, 2018.
  1. koukilights
    koukilights Junior Member
    Colorado
    So I'm getting the P0A80 CEL every now and then. Sometimes twice a day, sometimes not for a few days. I have typical bad HV battery symptoms.....except when it's cooler outside.
    On a hot 90 degree day with the AC blasting and driving around, all the symptoms show their ugly head. But last night it had rained and it was around 55 or 60 degrees and it almost seemed like my car was normal again.
    My battery temps were back down to the 110-118 degree range (usually they're 125ish), my mpg's were going back up, my pedal response was a lot better.
    What do you think? Bad batteries causing excessive heat and cooler weather helps cool them off better? Or a bad fan that isn't flowing enough air to keep batteries cool, and the cooler weather just assisted in cooling them off?
  2. Prodigyplace
    12,713
    11,848
    Central Virginia
    Is the fan clean? A dirty fan can cause the battery pack to run hot. I assume you are running your Air Conditioning at a comfortable temperature when it is hot outside.
  3. koukilights
    Colorado
    Yes, fan is clean. I just checked it a few days ago. Bit of dust build up but nothing that would impede it's performance. Hell, I see dirtier fans than mine being sold on ebay.
    I run the AC on auto mode and keep it at about 70 degrees most of the time.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes heat stresses a battery more but there are additional codes for heat related issues. How are you reading the codes? Some apps allow fan testing and/or monitoring of fan speeds. The P0A80 code is for a failed/weak battery.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    2005 Prius, I'm just going with early symptom of dying Hybrid Battery.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I do think PA080 in rare cases sometimes is due to clogged cooling fan causing overheat. But you are saying fan is clean, so probabilities are going down further.
  7. bisco
    52,855
    can you hear the fan speed increase when you are driving and the light comes on? maybe it isn't operating properly. certainly worth testing before replacing the battery.
  8. koukilights
    Colorado
    Yeah, 2005 Prius with 190k miles. I know the batteries are probably at the end of their life, 13 years is quite a long time.
    I'm monitoring temperatures and scanning codes with torque pro and a bluetooth adapter
    I haven't noticed a correlation with fan speed and the CEL but I do hear the fan blowing at full blast sometimes and other times it's quiet and not blowing.
  9. bisco
    52,855
    that would tell me it is working properly.
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    ...working properly, and battery pack already on its way south too!
  11. koukilights
    Colorado
    RIP battery pack lol...damn
  12. Prodigyplace
    12,713
    11,848
    Central Virginia
    If you are DIY you may want ot consider a kit of new cells from @2k1Toaster here for $1600 shipped. The website link is in my signature,
  13. JC91006
    16,936
    8,647
    If the fan is causing cooling issues, it would have a code of its own. What you have is a battery code, need replacement
  14. koukilights
    Colorado
    Yeah, I've seen those replacement batteries by that guy. I'll consider it. I looked into it a few months ago and he never seemed to have any in stock.
    Yeah, that's what I figured, a bad fan would throw a fan code. I'll go ahead and look into a replacement battery pack
  15. Prodigyplace
    12,713
    11,848
    Central Virginia
    He has trouble keeping them in stock. Sometimes @TMR-JWAP here has battery packs available
  16. The Electric Me
    9,083
    5,801
    I would caveat my own advice by saying obviously I'm guessing. But since the thread asked in a binary fashion, Bad Battery or Bad Fan, I'm placing my bet on "Bad Battery". But it is only a guess.
  17. koukilights
    Colorado
    That's what I was thinking too, just wanted to get a few more ideas going or confirmation of my suspicions
    Raytheeagle likes this.
  18. strawbrad
    953
    1,007
    Install the free apps Hybrid Assistant and Hybrid Reporter. You already have the bluetooth adapter needed to run the apps.
    These apps will show exactly what is going on inside your battery.
    Brad
    Prodigyplace likes this.
