Bad Hybrid Battery or Electric Motor?
Discussion in 'Gen 2 Prius Main Forum' started by PrayForMyPrius, Aug 30, 2019.
  1. PrayForMyPrius
    PrayForMyPrius Junior Member
    17
    Iowa
    Was driving and all the lights came on (big triangle, check engine, stability control) and power started getting very very sluggish.
    The dealer repair shop said Battery Cell 11 has a short.
    Take it apart, and test voltages. Battery Cell 11 was marked (from a previous tech, I don't think these guys got down that deep, just ran a quick test) but it was cell 8 that measured 6.7 voltage, cell 11 seemed fine.
    Replaced cell 8 with a new cell, put back together, everything seems fine, full power while driving, then it happens again. Lights come on, sluggish driving. It even seemed to ONLY be using the engine, no electric motor.
    I tried putting the 6.7v cell into battery cell 11's spot, thinking maybe it has a short but can't detect it with voltmeter. Again, put together, car seems fine, but like 10 seconds into driving, lights on and sluggish driving. It DOES use the electric motor (according to the info screen anyway) but the engine is coming on to charge the battery like every 30 seconds.
    Other symptoms:
    The battery exhaust fan is constantly on high
    The electric motor seems to make a constant slow "whiirrr... whirrr... whirrr.." sound. After running a bit, it seemed to slow down and get quieter, but remained.
    Saw something about the water pump, checked that and it seemed fine.
    I have a lead on a full gen 3 used battery for only 350 if I trade in my battery, from a junk yard. Said the gen 3 has 200k miles on it, but was scrapped because of engine failure, battery is fine.
    My biggest worry: could it be the electric motor? Could I take the gen 3 electric motor, if so? Is the electric motor cheap and easy to install? Or does this all sound typical for a failing hybrid battery?
  2. PriusCamper
    PriusCamper Senior Member
    13,433
    5,422
    Pacific Northwest, USA
    Worrying about the electric motors is worrying about a super rare occurrence... And pack price, it's a little high for an unknown pack, but good enough. Of course you have to decide if your pack once fixed will last longer than replacement, which makes giving up your pack the gamble. The people selling to you are making an offer based on what's a good deal for them. They assume you have a good pack with one bad module and they'll recondition pack and resell... As always, the more you learn/experience you have, the lower the overall costs. Everyone should keep a spare Prius HV battery pack in their garage & just swap 'em periodically for testing... That's my philosophy... But I guess that's too much nerd for most? :)
  3. strawbrad
    953
    1,007
    Wow! You have a lot to learn.
    First thing is to remember is these batteries can kill you.
    The Gen 2 batteries has 168 cells. The cells are packed in 28 modules of 6 cells each. The dealers computer scans modules in groups of two referred to as blocks. The count starts on the side opposite the battery computer.
    The dealer told you one of the modules in block 11 had a bad cell. It's the module that measured 6.7 volts. Block 11 is the two modules that are the 21st and 22nd from the side of the pack opposite the computer. They are also the 7th and 8th modules from the computer end. What you called "cell 8" is actually one module in block 11 that the dealer told you was bad.
    Get a code reader! Learn how to do a forced charge and discharge!
    You need to be much more careful and know more to properly repair your battery properly.
    Skibob and Raytheeagle like this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Since your in the Gen 2 forum I’m guessing you have a gen 2 Prius? You can’t do a straight swap between a gen 2 and gen 3 battery pack. You can change the battery modules between them.
  5. PrayForMyPrius
    17
    Iowa
    I see, so I could ONLY pull the battery blocks out (all 28 or whatever) and put that in? But NOT the relay / hookups / housing etc?
    Is it likely that I have a problem with the relay / housing / hookup? Or does it sound more like just the cells themselves?
  6. PrayForMyPrius
    17
    Iowa
    Yes, I mispoke between cell and module and block.... and yes I had everything disconnected safely.
    The mechanic told me block 11 had a short. I looked inside, found a mark on block 11 (don't think from them, from a previous mechanic) but the voltage read 7.8 full voltage as the rest.
    I found that in block 8, I had 6.6 or so. So, I replaced this with a block/module I ordered online, and every part read 7.8 or so.
    However, I had the same problem.
    I tried putting the 6.6 block into the spot of block 11, just in case it had a short or problem that I couldn't detect. Same problem when starting up. I can drive a bit, but usually it won't give me any juice from the electric motor.
    So, I have access to a gen 3 battery. Are they not compatible fully with the gen 2? I could take out ALL the blocks (all 28) and put them into my enclosure? But theoretically, I could have a problem elsewhere other than the blocks? Perhaps the relay, wiring, or something else?
    If I go to order online, such as refurbished or brand new designs, is this typically ONLY the battery pack, and not the relay or anything else? Is it common for the relay and other hookups to be the problem? Or does it just sound like it's my battery pack / cells?
  7. bisco
    52,807
    any corrosion inside the battery case, or the connections?
  8. PrayForMyPrius
    17
    Iowa
    Tried cleaning all the connectors, water and vinegar solution, rinsed well and dried. Don't see any obvious corrosion, though.
  9. JC91006
    16,936
    8,647
    Change out the bad module in block 11, and call it a day. Why did you replace a bad module with another KNOWN bad module? I don't understand the repair thought process, you're just wasting time and questioning your work afterwards.
    Also a voltage reading of 7.8v means nothing, does not tell you that module is good.
    If a computer is picking up that block is bad, just replace that block. If you have more skills then find the bad module in the pair. If you don't have that skill, replace the entire block
    Raytheeagle and strawbrad like this.
  10. strawbrad
    953
    1,007
    It seems like you still don't understand.
    Again, block 11 is the the two modules that are in the 21st and 22nd position with the count starting opposite the battery computer. They are also the 7th and 8th modules counted from the battery computer. What end of the pack are you counting from? A block of two modules will not read 7.8 volts. That would be the voltage of a single module.
    You did not measure the voltage of a block of two modules at 6.6 volts. You measured the voltage of one module at 6.6 volts. This module is the 21st from the end opposite the computer and the 8th module counted from the battery computer.
    The 6.6 volt module (not block) is dead. It was counter productive to put that back in the pack. I'm not sure which module you replaced with the dead module.
    The Gen 3 modules can be interchanged with the Gen 2 modules. Everything else is different. I would not expect a 200K Gen 3 pack to work as is if it as sat unused for any length of time. It's not a good deal if you have to give up your core. Both the Gen 3 and Gen 2 batteries have 14 blocks and 28 modules. They do not have 28 blocks (pairs of modules).
    The relays and such rarely break. Be careful with the small voltage sensing wires. They are easy to break. Other than the bad battery modules the other area of concern is PEBCAK. ;)
    dolj and Raytheeagle like this.
  11. PrayForMyPrius
    17
    Iowa
    Ok thanks I understand now. 6 cells per module, 2 modules per block.
    Yes, I knew it was stupid to put the 6v module in, just figured maybe the one that was marked with pen had something I couldn't read with a voltmeter, and needed to come out.
    I'm realizing after talking with a few shops, even if these two modules were the problem, and I had two from the internet (not just one like now) to replace them both, I would STILL need to use a charging kit to get the voltages even.
    If I had all good modules, but they hadn't been calibrated with a charging kit, would it likely give the same problems?
    Right now, I can't even get it to turn on and go into gear. Let's me put it in neutral is all, and a loud click from the relay, and it doesn't read anything from the prius battery.
    Very frustrating because I drove it to a mechanic to look at it, then they can't even really get it on or anything. They felt pity and won't charge me, having it towed to a mechanic that CAN fix it (fingers crossed) - quoting 1700 or so for a rebuilt battery (or new cells, I'll have to inquire), think I just have to eat the cost at this point, running out of time before next job starts.
  12. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    In reality he probably changed a module with no problem with the defective one, as he seems to be counting the modules from the wrong end. (He should be counting them from the end opposite the ECU.)
    What he needs to do is remove the defective module he swapped in and reinstate the original one he took out.
    He also really needs to take the time to understand what Strawbrad is telling him.
    A picture is worth a thousand words:
    #12 dolj, Sep 5, 2019
    Skibob, JC91006 and strawbrad like this.
  13. Prodigyplace
    12,711
    11,848
    Central Virginia
    Your best bet for reliability may be the kit of new cells sold by @2k1Toaster and listed in my signature. $1600 basically gets you a new battery pack Replacing bad modules with other used modules may extend the existing pack but it will fail again. You cannot buy new modules except in a full pack from a dealer willing to sell you the part. Many only sell the pack if they install it.
  14. Skibob
    2,912
    1,505
    Northern California
    Actually you can balance the modules without a charger but it takes a lot of wire and a day or two. Remove all the buss bars and connect all the positive terminals together and all the negative terminals together. Then let sit for a day or two. I think it talks about it somewhere in here.
    Gen II Prius Individual Battery Module Replacement | PriusChat
  15. JC91006
    16,936
    8,647
    This actually doesn't do anything for the modules. Their capacities are all different, all 28 modules are completely different. Only way to properly balance them is with charge and discharge cycles, get them back to similar capacities.
  16. Skibob
    2,912
    1,505
    Northern California
    So it doesn’t balance the voltages? That was what he was asking about.
  17. JC91006
    16,936
    8,647
    The voltage reading on a module is almost a useless reading, it doesn't tell you anything. Only useful info is if you have one under 7.2v, you can throw it away. There's no other meaning to the voltage readings.
    The method you described makes all the voltages look similar, until the car gets started and all will be off again. It's the capacity of the module that's more important.
    strawbrad likes this.
  18. strawbrad
    953
    1,007
    Are you SURE you put the orange plug in correctly? I know you have taken this battery apart a bunch of times but this sounds like the the lever has not been pushed down.
    $1700 is too much for a rebuilt battery. At the price you might as well get a new battery from Toyota. If you can get the car to MN I can install a rebuilt battery for $850.
    Skibob likes this.
  19. dolj
    dolj Senior Member
    8,635
    4,389
    No, it equalises the voltages, which as JC has stated is pointless.
    Very confusing.
    How did you drive it to the mechanic, if you can't even get it to turn on and go into gear? How is it that after driving it to the mechanic, they can't even really get it on or anything?
    #19 dolj, Sep 5, 2019
    Prodigyplace likes this.
