Bad knocking from top of engine...won't start
Discussion in 'Generation 1 Prius Discussion' started by Blotto, Nov 30, 2018.
  1. Blotto
    Blotto Junior Member
    36
    17
    2001 Prius
    I
    John,
    Thanks for the advice!
    Unfortunately, its too late - I've already applied the stuff on 2 plugs and put them in the head.
    When you posted, I was actually googling how much to decrease the torque if anti-seize is applied. I found some sites that say 20 or 30%:
    sorry can't post a link - but google:
    ngk spark plug torque anti-seize
    Then I was searching for a Workshop Manual and it suddenly struck me that I actually have 2 (!) repair manuals for this Prius that I'd forgotten about.
    These are a Haynes and a Chilton. They must have gotten their info from the same source because some of the photos are exactly the same.
    Anyways, both recommend anti-seize (with no mention of a decrease from their 156 in-lbs) and show a photo of someone lathering it on with a flux brush.
    PLEASE MR. MODERATOR: Can I post a scan of this photo?
    I've no clue if anti-seize is right or wrong - just thought I'd throw this out there.
    Cheers!
    FireFighterHill and Raytheeagle like this.
  2. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    is your valve cover gasket leaking? This can cause oil to fill the COP tube. Id either tighten the valve cover or replace the gasket.
    Raytheeagle and Blotto like this.
  3. Blotto
    36
    17
    2001 Prius
    I
    Fire Fighter Hill,
    Excellent idea! I'll try re-tightening (84 in-lbs in 3 or 4 equal steps, when installing the cover, according to the Haynes Repair Manual).
    I'll order up a gasket when I get the coils, plugs etc.
    I have to start paying attention to this car.
    Thanks!
    Raytheeagle likes this.
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Good catch, the oil and obviously moisture have combined to form "fondoo" as "we" lovingly call it ;)
    Blotto likes this.
  5. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Make sure the gasket set you buy include the COP gaskets. Some dont. I prefer Fel-pro brand myself.
    SM-N960U ?
  6. Blotto
    36
    17
    2001 Prius
    I
    John,
    "Fondoo" - good one. Strange stuff indeed, looks like mud.
    FireFighter,
    Good call on the COP gaskets - RockAuto has it - only $8
  7. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Part number I got for the valve cover gasket is
    VS 50624 R
    Blotto and Raytheeagle like this.
  8. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    84 ft. lb. for a valve cover is too much. Look it up again. I'd suspect that that's head bolt torque.
    Blotto likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Blotto said 84 inch pounds in post #23;).
    Sounds about right (y).
  10. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    DOH! Thanks Ray!
  11. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    I'd clean everything up with brake cleaner, install new V/C gasket and seals, a set of new plugs, new coils. You can get the cheap, economy parts, plugs and coils. Probably clean or replace air filter. The would give adequate service for 30K or so miles. Rock Auto has all that stuff. Remember to use the 5% off code. I love the Rock!
    Resale on your high mileage Prius would be minimal. If you can get it running right, it'd be a good, cheap second car. Or do what I did, practically give it to a graduating senior that's going to college. They are awesome kids cars, very safe, economical, and pretty fun to drive. I sold mine to a young woman starting college this fall. Advertised it 10% off to a HS senior--figured no male HS student would want it. Too practical!
  12. Mendel Leisk
    42,369
    With clean/dry threads. If you use anti-seize maybe a bit less, say 12~13?
  13. Blotto
    36
    17
    2001 Prius
    I
    Thanks for all the additional comments, folks.
    Right now I'm struggling removing #3 plug. I sprayed PBlaster yesterday down the "well".
    I've never had a plug so tight before. I'm not a big bruiser of a guy and I'm using a regular 3/8" socket set. But still, I feel like something is going to go bang. Maybe I'll give it another shot of PBlaster and wait 'til tomorrow. The other 3 plugs came out so I don't want to blow it on this one, if you know what I mean.
    Update: Just found a 14" breaker bar. My regular socket handle is 8" regular. Might give the breaker bar a go.
    OK, If #3 comes out, here's the plan:
    Replace plugs with new cheapo NGKs.
    Erase engine codes.
    See if she fires up.
    If she does, I will be ecstatic. Would you expect remnants of PBlaster to trigger new codes or will the remnants be blown out before they are sensed? Will shall see.
    #33 Blotto, Dec 2, 2018
  14. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Don't use the cheap non iridium's. use iridium. I tried that route and the car didn't run as smooth as it did with Iridium.
    Blotto likes this.
  15. Blotto
    36
    17
    2001 Prius
    I
    Sadness reigns.
    I got the last plug out OK.
    However, after installing new plugs, the knocking is still there:
    https://photos.app.goo.gl/ouCJNvuphivLZyDK7
    The new error codes are all misfires:
    P0300
    01/06
    P0301
    02/06
    P0302
    03/06
    P0300 P
    04/06
    P0301 P
    05/06
    P0302 P
    06/06
    I'll take the plugs out tomorrow and see if they are soaked in oil, maybe that would be the problem.
  16. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    The coils could be the cause.
    What plugs did you get?
  17. Blotto
    36
    17
    2001 Prius
    I
    Yeah, I know what you mean but right now I just want to see if it is only an ignition problem or if it something bigger and not worth fixing.
  18. Blotto
    36
    17
    2001 Prius
    I
    Ray,
    Cheapo NGKs non iridium - BKR5ES-11 2382 - they are listed on the NGK website as suitable for the 2001 Prius.
    I'm thinking of taking Brian's advice:
    "...You can get the cheap, economy parts, plugs and coils. Probably clean or replace air filter. The would give adequate service for 30K or so miles. Rock Auto has all that stuff...."
    Just to see if the car runs.
  19. Blotto
    36
    17
    2001 Prius
    I
    Oh, I forgot to mention:
    The "coils" are a really loose fit over the spark plugs - it that normal?
    On my 1990 Camry (289k miles) you really have to twist the plug leads to get them off the plugs. Of course, that car has just the one coil.
  20. padroo
    padroo Senior Member
    2,763
    2,253
    Spark plug changes on high mileage cars need to be done more often than the book calls for in my opinion.
    The valve cover leaks need to be fixed and those oil soaked coils are questionable at best. With all that contamination around the spark plug coil gives high voltage a place to travel to ground. Once it finds a path it will crate a carbon track and traces can be found on the porcelain of the spark plug and inside the coil.
    Part 3 -Carbon Tracks are a Common Cause of Ignition Misfires
    Blotto likes this.
