Bad mileage, bad gas, car computer adjusted??
Discussion in 'Gen 2 Prius Fuel Economy' started by J_w73, Oct 22, 2009.
  1. Bob64
    1,540
    93
    Virginia
    About the AC: Did you have it set to a specific temp?
    If so, thats why. Cooling you down from 90+ takes more energy (gas) then cooling you down from 80.
    OR did you do max cool and just turn the fan speed to low?
  2. J_w73
    J_w73 Junior Member
    67
    no.. just on low temp and low fan.... so it was blowing the same the whole trip..
  3. Bob64
    1,540
    93
    Virginia
    What do you mean by low temp? 65 degrees?
  4. J_w73
    J_w73 Junior Member
    67
    with the temp setting on LO.. the fan setting on LO.. and the AC on. with the outside vent closed.
  5. richard schumacher
    7,686
    1,068
    United States
    Well (unless I misunderstand something here) no wonder: at the lowest temp setting the AC compressor runs continuously. I don't see why you'd want to do that when the outside temp is 50'F.
  6. J_w73
    J_w73 Junior Member
    67
    no.. I am saying that during that "bad tank" it seemed like something changed on the last part of it and the next fill up. I was getting booming mpg.. .. after the bad tank I am getting like 61 mpg trips.. where as before the "bad tank" I never got that much mpg according to the MFD.
    I was saying that the weather was 80-90's with the ac on before and after the "bad tank"
