Bad mileage myth?
Discussion in 'Gen 2 Prius Main Forum' started by DocVijay, Mar 13, 2006.
  1. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    You might make plenty of short trips, but a far greater percentage of your tank is very long trips.
    As near as I can tell, the Prius must spew uncombusted gasoline out the tail pipe when it's warming up, because the milage during that time is really, really bad. For me, it's typically 35 MPG in the summer for the first 5 minutes and 25 MPG in the winter for the first 5 minutes.
    So, I think it's well established that during warmup, the engine's efficiency really sucks. Now let's examine that "I make plenty of short trips with a cold engine" comment.
    My wife and I each have a Prius. I've been getting 48 MPG or so for the last couple of weeks and my wife is getting 35 MPG. When it was colder, I was getting 43 and she was getting 30.
    Now lets compare her drive and my drive. I commute 16 miles for about a 30 minute commute. On the weekend, I might make 3 or 4 short trips of less than 10 minutes. So, monday through friday, I spend 5 minutes getting bad gas milage and 25 minutes of really good gas milage for each leg of my commute. So, during the week, I spend 50 minutes getting bad gas milage and 250 minutes getting really good gas milage. On the weekend, my 4 or so trips of less than 10 minutes contributes an additional 20 minutes of poor gas milage and 20 minutes of good gas milage, resulting in a one week total of 70 minutes of really sucky gas milage and 270 minutes of really good gas milage.
    Therefore, for my driving, I'm getting good gas milage for approximately 80% of my driving.
    Now lets look at my wife's driving. She is a stay-at-home mom and primarily goes to gym, drops my daughter off at kindergarten, and goes to local stores. Most of her trips are 7 minutes or less, and many are less than 5. I'm not going to try to do the math, but it should be obvious that for her driving patterns, instead of driving 80% of the time with a warmed up engine getting good gas milage, she is probably driving closer to 80% of the time on a cold engine getting bad gas milage.
    Now you, with your 120 mile commute, even with local trips in the evening or on the weekend, are probably driving approximately 90% of the time with a warmed up engine getting good gas milage. That's why you get good gas milage without even trying and why other people can't get good gas milage no matter what they do.
    I would bet that if everyone accurately estimated the percentage of time they drive with a cold engine and the percentage of the time they drive with a warm engine and then used the following formula, they would come close to their real world milage.
    Pcold * 60 + Pwarm * 35 = mpg (for summer temps)
    Pcold * 50 + Pwarm * 25 = mpg (for winter temps)
    Where Pcold and Pwarm are between 0.0 and 1.0. (80% = 0.8)
  2. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Well, yes, the flatness does also play a part.
    Now, as Dave pointed out, the A/C use also has a big impact. In Florida we use A/C every day. The recent figures I've pointed out are WITH the air conditioner. Even in the lower 80's, a car gets very hot here in FLorida after sitting in the sun for hours and hours. I always use A/C.
    The other point that I forgot to reinforce, is the larger, heavier wheels. When I proposed it (and others have too), there were numerous replies about the steep drop in mileage I would get. The Scion tC wheels/tires each weigh just over 10 pounds more than the stock Prius wheels. Some people posted apocalyptic results on my mileage. Yet those have not materialzed. Overall I only lost about 0.7 mpg so far. The wheels tires must be factored in as well.
    So, with ALL these factors taken together:
    - significantly heavier wheels/tires, larger tire contact patch, higher rolling resistance
    - constant A/C use (set to 72 degrees)
    - long drive with lots of stop/go congestion
    - inefficient driving
    - flat terrain
    - mid 80's temperature
    Consider all those and then look at my 51 mpg. Consider all those and that I TRIED to get the lowest possible and got only 40 mpg, and it's even more impressive. You really have to do a lot to get those really low numbers. Now if it's well below freezing and you only make a short (<5 miles) trip, then yes, I guess getting 35-40 is reasonable. But there are some who are getting mid 30's and it's considerably warmer. There are some who are complaining of getting much worse mileage on longer drives. Those are the ones I'm questioning.
  3. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Outside temps matter (~5 mpg at in low 20's F, vs > 50F), but engine temp matters a whole lot more. I drive many jaunts of 10 miles in 25 - 35F weather through the winter, usually with 2 - 5 hour intervals when the car gets to cool off. IF I wait to turn on heating for 5 minutes, and only use it on uphills or accelerating, my FE is about 55 - 60 mpg at night with no traffic to speak of in suburban/city driving. For comparison, if I use AC with abandon, mpg is in the 40's (I know from my wife's habits), vs 65 - 70 mpg in ideal weather.
  4. andreaswin
    andreaswin New Member
    72
    NORWAY
    well 40 pound ca18kg right ?) in total isnt that bad is it ?
    I Guess there is many factors that will affect how much more gas your car will use when putting on heavier weels,, and that would affect more in acceleration gas usage and performance , when ure in desired speed it shouldnt affect the gas/milage that much.
    And i theory you sould get alittle more back in power to the batteries when ure deacceleration ( "flywheel " effect should affect both ways.....)
    It also depends where in the weel You have the new 10 pound weight , distributed allover in same pattern as the original weels or ?? and so on..
    my experince is that the tire itself plays a big role in gas milage. the pattern of the tire, profile bla bla
    i might be utterly wrong ,
    aslong it looks good on the car and not made of lead :D ..... im happy
    *Andreas
  5. DocVijay
    1,455
    Tampa, FL
    Yes, 40 pounds is not a lot of weight, but this is a rotating mass, and is unsprung weight. These two things have a much greater affect on mileage than putting 40 pounds in the trunk, etc...
    You are also right in that in highway driving the mass has a lesser effect, but you really never go at a "constant" speed. It always varies some. But it is less than in city driving. I do both though, so any benefot on the highway is offset by city driving. Quantifying the exact tradeoff balance is pretty impossible to quantify without some seriously advanced telemetry...
    I also considered the "flywheel" effect as you stated. Once again I really don't have any way of quantifying it though, so your guess is as good as mine. Well, unless your're an engineer, in which case it's probably a little better than mine.
    Also, the distribution of the mass is definitely a factor in the amount of energy required to change the rotational speed. If the weight is concentrated farther out, as it is in a plus size wheel/tire, it is harder to change the speed, i.e. more energy to accelerate. If the mass is conentrated more towards the middle of hte wheel, it takes less energy to change the rotational speed.
    Rotational friction from the tire is actually static friction, as the surface of hte tire is not sliding along the pavement (at least not ideally...). By increasing the tire's contact patch you do increase this friction.
    However, the greatest source of frictiona nd power loss for a car is thorugh air resistance. A lower Cd certainly helps, but at a certain speed more energy is spent fighting this frinction from the air than any other source. Speed definitely kills (your mileage).
    So to sum up, I agree, if it looks good and isn't made of lead, it's all good.
  6. DocVijay
    1,455
    Tampa, FL
    Well as I stated earlier, in cold climates, a block heater can do a lot to help those winter mpg blues.
    As for the A/C, when it's 95 degrees and 100% humidity, you have no choice but to use it in Florida. Any mileage I quote is assumed to have the A/C on by default.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    all in all, i have to agree with the Doc. the whole basis of this thread is not understanding how people can get very low mileage. sure there are extremes. the first winter i had my car, i was in a training class that was 1.1 miles away from my front door. it lasted 6 weeks. we had 60-90 minutes for lunch, most of which i spent at home, on the computer, here at Priuschat (bet that was a shocker to you!!) so that was nothing BUT short trips. and my mileage was in the mid 30's. but a few trips of 70-80 miles on the weekend was enough to bring me back to the low 40's.
    back when i only had 3000 miles on my car, i helped a friend deliver the morning paper. that was over 160 stop and go deliveries. only did 4 days worth but during that time (i did fill up the night before i started the 4 day run) i averaged 41 mpg. granted it was summer time, but this is WA State and at 3:30 in the morning, it aint that warm no matter what time of year it is.
    but there have been a lot of people who have 20-30 mile commutes on the freeway or some variation of, claim to drive very conservatively and still get mileage in the 30's. i have to side with DocViJay. i simply dont see how it could be done without driving like a maniac.
  8. daniel
    14,487
    1,518
    Spokane, WA
    Recipe for 29 mpg:
    Park your Prius in an unheated garage when the outside temperature is 30 degrees below zero Farenheit. Start the engine and turn the heat on full to pre-heat the cab for 5 minutes before driving, because at 30 below zero your fingers would freeze and break off. Drive 4 miles in 10 minutes without the car ever getting into Stage 4 operation, and with the heater on full blast all the way, so the engine never shuts off. Park the car. Jog at the YMCA. Start up the car and drive 2 or 3 minutes to the office, and park again. In the afternoon, when the temperature has warmed up to a tolerable ten degrees below zero, drive back home, again with the heater on full blast, though this time without a pre-heat. Don't use the EV switch because you didn't have one that first winter when the car was new. But do accelerate hard because you are in a hurry to get back into a heated building.
    And, no, you would not like riding along. It's too confounded cold. Which is why I don't live there any more. 29 mph is not too hard to achieve. Here in Spokane I'm getting 50 mpg and satisfied with that. Fargo's a nice place, but you have to be half polar bear to survive the climate.
  9. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    OK Daniel. Good point. I've heard you and other like Jayman mention those conditions. That makes sense, no arguments here. However, it seems that people in much milder climes have experienced similar results. That's who I'd like to ride along with (no offense :D)
  10. daniel
    14,487
    1,518
    Spokane, WA
    No offense taken. But has anyone actually gone below 30 mpg without bitterly-cold weather, or a one-mile commute? Take a look at your first 5-minute segment, and consider the person whose daily drive is 5 minutes.
  11. DocVijay
    1,455
    Tampa, FL
    Well Daniel, you are absolutely right in your scenario, but as tripp pointed out, there are those in much more moderate climes that are getting those numbers. In an extreme situation like yours (30 below zero!) I would be more surprised if it got better mileage. At those temps, many average cars will not get more than single digits for mileage. So as I said in another post, it's all relative. So even at 29 mpg, the Prius is performing spectacularly considering the conditions.
    As with tripp, the people I'm talking about are those who may live in Florida, Claifornia, or comperable locale, and while others are getting 40, 50, or even 60 mpg, they are still getting 30. Those are the situations I don't get.
    As for me, now that my week long test is over, and I've resumed my normal driving habits, my average mileage is right at 45 mpg. Am I complaining? Nope, as it's still over 3 times my previous cars mileage. Considering the aftermarket wheels, average speeds (~80 mph), and general prodigious use of the throttle, it's actually still really good mileage. In my Explorer I would only get 13 mpg highway, and that was with slightly slower top speeds.
  12. DocVijay
    1,455
    Tampa, FL
  13. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    Who are the people in Florida & California getting 30MPG? Are they on PriusChat?
  14. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    Last week I went to the dealership for a "new Toyota owners night". The interesting part was when they divided us into Prius and non-Prius groups for a shop tour. There were about 8 Prius owners and a couple who owned a Highlander hybrid that attached themselves to our group. Our "guide" was described as the sevice department's " master diagnostician". The Highlander couple kept bitching on how they weren't getting the EPA mileage and how unhappy they were about it. They were a couple of a--holes who wouldn't give our guide a break or even respond to questions about tire pressure, driving habits, etc.
    After they stormed off, the guide told us about a mileage problem he had with a Prius a few weeks ago. Angry call - owner was only getting 12 MPG! After the usual fighting back and forth with the various layers of the service department, it landed in the "master diagnostician's" lap. He asked the person to bring the car in. When they did, he went out with them to look at the car and as he approached it the engine came on. It turned out that the owners thought that was how it should operate. They had not listened to the sales guy at delivery or bothered to read the manual. The car had been on since they picked it up. They had been through several tanks of gas and had been keeping it in their garage (thank God for low CO emissions?). Our guide explained the Power Button, demonstrated it, reset the consumption screen, and sent them on their way.
    So that's one way to get 12 MPG. I got the impression from questions that I was the only one there that night that had read the car's manual (Prius owners or not).
    - Tom
  15. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Daniel:
    Been There, Still Doing That.
    The winter front and Mobil 1 0W-20 made a *huge* difference this winter. We were unusually warm most of the winter, but in Feb had enough -30 to -35 C weather to make up for it. I never got worse than 6.8 l/100km tank average, ccompared to 9.8 l/100km last winter.
    Of course, a Prius that is getting "only" 9.8 l/100km is still getting *way* better than every other car around it. My co-worker with the '04 Golf TDI actually gets 10% worse than I do in winter driving, and he has to put up with a diesel in very cold weather.
    As far as the effect of tires, I noticed when I took off my Michelin Harmony on the OEM wheels, and put on the Yokohama Ice Guard on steel wheels, my tank average went from 4.8 l/100km to 5.1 l/100km.
    jay
  16. daniel
    14,487
    1,518
    Spokane, WA
    I gotta say that, for all of Spokane's disadvantages (bigger city than Fargo, not as friendly) I am really happy to not have those bitterly-cold winters. About half-way through my present tank, the tank average is 51 mpg. Of course, part of that is, being a bigger city, I have to drive farther, which I don't like. But I was never made for severe winters.
    One thing I've noticed is a mileage killer is making a lot of stops: After every stop the car seems to burn a bunch of gas right away. Someone who makes a lot of very short trips with multiple stops is going to get worse mileage than someone who has a long drive without stops. At least that's how it seems to me.
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the stops are always a killer. too much kinetic energy lost and regen recaptures like what??? 3-5% i think i heard somewhere. not very good...
  18. DocVijay
    1,455
    Tampa, FL
    Well yes, I guess that's one way of doing it... :rolleyes:
  19. Begreen
    Begreen Member
    670
    Western WA state
    Well, I'm perplexed. Normally we are getting about 41 mpg right now. Granted that is mostly short trip driving, but even when I have gone on longer ones, it is rarely over 45. We have high pressure in the tires, and practice pulse and glide techniques. I'm not complaining, it's still cool out and short trips are hard on fuel economy. This is double the mileage of our old Subaru or the Honda Odyssey under the same circumstances.
    However, last night I stayed a little too long at a friends and had to really hustle to make the ferry. I had filled the tank just before stopping at my friends. With only 20 min. to get to the boat, I dashed out, jumped in the car and hustled to make it. At times I was up to 75 mph, hills and fuel economy be damned, I was on a mission and made the boat, phew! Took a deep breath and then looked at the fuel consumption. It registered 54.5 mpg with outside temp 46 degrees! This trip was about 9 miles, 70% hwy and 30% local streets. Now I'm perplexed. I broke most rules, quick off from the lights, gunned it on hills, but got great mileage. Wazzup?
    PS: I learned a little about the car's handling too, but that's another thread. I really want to get the BT plate installed now.
  20. habel
    habel New Member
    230
    Oslo, Norway
    We had a long trip with our Prius last week end, and I am very satisfied with the MPG. We averaged 57 MPG over a 9 hour drive, and it was freezing cold as well - so that the ICE was partly on sometimes just to give heat to the A/C.
    I expect to get closer to 60 towards summer!
