Bad mileage myth?
Discussion in 'Gen 2 Prius Main Forum' started by DocVijay, Mar 13, 2006.
  1. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    "The car had been on since they picked it up".
    Omygod! That is the funniest thing I've ever heard about the Prius. How,...just how do these people survive in our modern world??
    Just..WOW. I am not surprised by many things these days, but that one is a sad reflection of the, uh, ignorant society we live.
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I've found that I get better MPG with I accelerate fairly briskly off the line so that I get up to cruising speed as fast as possible. Even moderate acceleration results in pretty low instantaneous MPG and as others here at PC have pointed out the most important thing is to minimize the distance over which your efficiency is bad and maximize the distance over which the MPG is high.
    Oh, and turning the car off helps too! What a sod.
  3. micheal
    micheal I feel pretty, oh so pretty.
    842
    Lubbock, TX
    Just goes to show us, no matter how sophisticated the car is, it can't always negate the idiot factor. Their salesman should have explained how to turn the car on and off though, mine made sure I knew how to operate it.
  4. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Having purchased two Prii at that dealership and knowing two more guys at work who also purchased there, I am quite sure these folks got a complete overview of how to operate the car. There is one salesman who handles all the Prius sales and he drives one himself. I will ask him about this customer the next time I see him.
    - Tom
  5. daniel
    14,487
    1,519
    Spokane, WA
    Dave, I'm not talking about stoplights. (Though I think the recapture is more like 30 to 50% than 3 to 5%.) I'm talking about when you shut off the car to do an errand. When you start it up again it burns a bunch of gas in a warm-up cycle even if it has not had time to cool off. It seems like if I stop for groceries half-way home, my trip mileage is significantly worse than if I don't.
  6. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Yes, I do the same when I accelerate. At moderate throttle it will drop to 15 mpg and take 15 seconds to get to speed, but at full throttle, it drops to 12 mpg, and only takes 5 seconds. Doesn't take too much in the way of math skills to see which is better. Besides, ICE's are most efficient at full throttle, so it just makes sense.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well that is true to a point, but i think that is mostly because its a lot colder for you than for me. i do frequent short trips and stops and always try to do the stop the farthest away first to get my Prius warmed up. then the short trips back do fairly well with the mileage.
    and yes, accelerating briskly does help. because its nearly impossible to accelerate at any speed and get much more than 25 mpg. but even at 65 mph, at a steady speed holding to 50 mpg is easy.
    and the regen capture is very very small when compared to the energy used to get the car up to speed. to put it in perspective, it takes something like 30 horsepower to maintain the Prius at 65 mph. but try accelerating with nothing but a 30 horse power motor
  8. micheal
    842
    Lubbock, TX
    You are most likely right, I was just trying to think of how they could not possibly be that dense.
  9. DocVijay
    1,455
    Tampa, FL
    Unfortunately there are way to many people out there that ARE that dense...
  10. daniel
    14,487
    1,519
    Spokane, WA
    Yours only drops to 12 mpg at full throttle??? I don't remember the numbers, but I think mine drops to single digits if I floor it. (Which I used to do when it was new, because it's the most powerful car I've ever owned. - Now I accelerate with the flow of traffic, which I'd characterize as moderate acceleration.)
  11. outbackj
    outbackj New Member
    NY
    wow you have a solar roof on your new Prius?? I was told it was not available yet as there are problems with it & the battery. Wonder what's going on?:confused: Jan
  12. fred garvin
    fred garvin New Member
    376
    56
    northern virginia
    you were told wrong
    they are available, in limited quantities, as toyota underestimated the demand (probably assuming that in this economy people would not want the $1800 solar sunroof). I saw a figure of 7% as equipped with the solar roof (which comes with NAV).
    this i am told is being corrected and higher quantities are expected in August or so. my solar equipped IV should be delivered late next week.
    also, there has been info that many of the initial solar roof cars were delivered to the pacific northwest, and very few to other regions.
    finally - what you heard may be a reverb of something that did happen. Toyota attempted, i understand, to make the solar system "charge" the traction battery but the set-up created interference with other systems so they stepped back the purpose, for now, to only powering the vent fans.
  13. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    does anyone know what is the additional weight of the solar/sunroof over NOT having it? is it a considerable weight difference?
  14. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    I belive someone here posted it was 28 lbs more by having it.
  15. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    These would be the same people that, in a 'standard' vehicle with an MPG rating of 25 are actually pulling 15-18, because of their driving habits.
    Just consider that if someone is getting 'abysmal' mileage with a Prius, how much worse it would be with something else!
    Even my DH, driving exactly one mile to work, in the winter, was able to get 44 mpg or better, generally. Weekend trips to get groceries helped to bring it up a little, however.
