Bad Piston Rings?
Discussion in 'Gen 2 Prius Main Forum' started by Organfreak, Jan 17, 2020.
  1. ydpplqbd
    ydpplqbd Active Member
    551
    254
    Wow!!! That is one clean engine!!!! Can I buy your Prius when you sell it?
    Aaron Vitolins, edthefox5 and SFO like this.
  2. Organfreak
    Organfreak Junior Member
    48
    17
    Gig Harbor, WA
    Thanks very much for all that, Ed! Given all of this, I've decided to walk away from this nice looking, nice-driving Prius. Too many unknowns here, and this car lot gives me the feeling that they're trying to fool me. Gonna settle for my 2nd choice, a 2013 Mazda 3.
    Tim Jones, bisco and edthefox5 like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Curious why you would be disassembling your engine? Not many people just go pulling valve covers/etc off a good running/good condition engine. What did you have going on?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Replaced plugs found Found oil in spark plug well #3 so replaced valve cover gasket. I wouldn’t call that
    Disassembling the engine.
    ydpplqbd likes this.
  5. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Life of Redline engine oil 10-30 with zddp package. It’s a 40 weight oil at op temperature.it stopped my minor oil eating issue. $10 a quart but u get what u pay for. It’s the only oil I have used on a g2 that stops the loud Solid lifter Valve clatter on this motor.
    Everyone touts oil additives screw that just use a really good oil.
    Tim Jones likes this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    That's all I'm really saying.
    Yes, I could be behaving entirely unfairly paranoid, in both incidences.
    But with used car purchases? I've found that approach to be much more a saving grace, then a problem.
    When I'm looking at...well any vehicle New or Used, I'd rather be present and see it's behavior from a cold start.
    When magically...the vehicle appears already warmed up and running?
    Well I'm not asking for a convenience or nicety here. Just let it sit, let it actually be cold, and let me see how it behaves starting up from that point.
  7. George W
    George W Senior Member
    939
    520
    San Antonio
    As the 3rd owner of my G2, I haven't noticed oil burning, but I see just a tiny amount at the bottom of the throttle body after 1 year. I was wondering where you purchase your 40 weight oil you use for yours. Thanks.
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Oil in the bottom of the throttle body is very normal. Disregard that.
    I buy my Redline oil at Jeggs.I use 10-30 which at operating temp is a 40 weight oil. keep the oil at the full line always.
    I also use Redline trans fluid D6 and Redline Water Wetter in the engine and Inverter coolant.
    There's some trans uoa's in the G2 trans stickys.
    Red Line Synthetic Oil | Free Shipping | JEGS
  9. Kaptainkid1
    Kaptainkid1 Active Member
    308
    248
    Los Angeles
    I would never buy a Mazda every again after owning 3 of them and they we're problematic. My last 2008 Mazda CX7 had a bad timing chain problem which happens around 100k for the engine in my model. Which was a 2.3L ford engine. If not found and replaced in time your engine blows up. The 2nd Gen Prius consider the most reliable car ever built in the last 20 years. After owning my Prius I did a lot research and did a lot maintenance because it had 150k and only oil change service records since new. She burns a little oil 1/4 qt of oil every 1000-1300 Miles. I keep an eye on it. I read these cars generally get 300k with very little maintenance. So far out of the 30 cars I've own so far this used Prius is the best so far as for reliably and comfort.
    Try to find another Gen 2 Prius with leather if possible. Or just one with good maintenance record. I promise you want be disappointed. The gas I've saved for the last year has put a smile every time I go to the gas station to fill up.
    SM-J737T1 ?
    #29 Kaptainkid1, Jan 29, 2020
  10. bisco
    52,858
    i put 27,000 miles on a miata with no issues
  11. Kaptainkid1
    308
    248
    Los Angeles
    He's not buying a Miata but Mazda 3 which has the 2.3l ford engine that was in my CX-7. That engine is problematic.
    Miata is probably the best car Mazda has made in the last 15 years. RX7 and RX8 oil burners. All the other models are crap.
    SM-J737T1 ?
    Raytheeagle, SFO and bisco like this.
  12. bisco
    52,858
    sorry, that was tongue in cheek :)
    Raytheeagle likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Bite your tongue and pull in your cheek:p.
  14. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    I was think I put 270k on a prius no problem :p
