Bad trans fixed itself?
Discussion in 'Gen 2 Prius Technical Discussion' started by Mpdcnva, Sep 27, 2023.
  1. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    For the pros on here, I have a good one. I have had a previous parasitic draw code with a sub code for the trans. I placed previous posts and we gave up on it, thinking we will eventually need to swap the trans. No issues, she runs good, but she would always throw that code, usually at slow speeds. For 18 months now, we have driven the car daily, constantly resetting the code. And as everyone knows, that code disables cruise control and stops the car from restarting. Instead of using Techstream, we discovered that a generic code reader could reset the system, even though it could not read the Prius code. As she continued to pop the code; it got so bad, (10 miles) we kept clearing the code while driving to retain cruise control. Again, 18 months, and now 2600 miles (she’s around 350,000 miles; new Michelins at 298,000 and Michelins are half worn) since the last reset, the trans has ???”burned”??? whatever was creating the parasitic draw in the trans. Keep in mind, the car never ran strange, ran bad, no noises, etc. just threw the parasitic code; sub code for the trans. Is it possible that whatever was causing the parasitic draw code (short) in the trans, burned up? This truly is an amazing car and has lived a rough life as a retired cops right foot commuter car. Always well maintained, but she’s been beaten on since 2004 with 5 miles pulling out of the dealership. I’d love to hear an experts assessment.
  2. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    AND she’s getting 54.2mpg highway. Last tank 550 miles when the gas gauge started flashing. 10 gallons. Thank you UREMCO for those kick nice person injectors. THEY made her achieve the gas mileage, better than when she was new. Likes oil, 1 1/2 quarts every 5000 miles.
  3. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    Sorry for the bad terminology. ISOLATION FAULT CODE, sub code for the trans.
  4. Mendel Leisk
    42,345
    Until then:
    1. What’s the codes?
    2. Do you know what transaxle fluid’s in there?
    3. Have you tried a drain-and-fill? If so, how did the drained fluid look?
  5. Tombukt2
    Tombukt2 Senior Member
    13,859
    2,518
    Durham NC
    I think he's talking to P0AA6 with the sub code for not the battery not the inverter but for the transmission I've never looked at the test that you need to do with the manual to determine what's actually bad inside of the said transmission I imagine there is a person on here that will be along to explain it in a minute but I do know that to fix it you're generally changing the transaxle or taking it out and busting it open and how cheap they are and plentiful they are and how rare this repair actually is in the scope of this vehicle You generally just buy it take out transmission and drop it in and be done with it. But I don't know the actual part that's failing in the transmission that's causing this and why it would burn up and then stop that is pretty good. Never seen any of our Gen twos with mileage like this I've seen 50.1 for a minute I generally get right at 500 mi to a tank and that's to the flashing light in a few miles Good show though for an '04 and a retired cops car. I generally have the '06 to 9 version but the same car were generally getting about 47 to 48 miles per gallon.
  6. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    Thank you P0AA6 with a techstream sub code pointing to the trans. I’ve owned her since new. Toyota Trans fluid change every 100000. Nothing in the fluid, always been well maintained but ALWAYS beaten on until recently. We have a spare trans ready, paid 90 bucks, but it hasn’t thrown the code for 2600 miles, versus every 10 miles. On thing. Retirement brought on a new easy going driver. 10 over the limited is good for me now. Car use to get horrible mileage until the UREMCO injector swap around 298000 as well. She’s 55MPG every tank since then. Every gen2 I swap the injectors gets over 50mpg. I would really like to know, whatever was frying, shorting out, freed itself clean?
  7. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    Unplug the orange plug in the HV battery. Remove the inverter cover. Unbolt 2 orange transmission cables from the inverter. Take a multimeter and set it to an ohmmeter. One lead to transmission case, the other to the orange transmission cable terminal, switching from one terminal to the other, testing all 6 terminals. You should see no movements on your multimeter which means there is no resistance (connectivity) between the tranny case and the electric motor(s) windings. If you do have resistance it means you have a short between the tranny case and the motor winding.
  8. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    When we determined it was the trans. (18 months ago) We performed the Toyota manual test with an insulation test multimeter. I can’t remember which motor it determined. But the test concluded it was the electric motor that had the isolation issue, but she never ran anything but good. I haven’t taken it apart again to re test. But since we’re at 3200 miles since the last reset, we’re leaving it alone. I can only assume, whatever was causing the leak burnt away? Or it’s about to blow in traditional noise and fireworks. We are somewhat baffled, but this car has amazed us over the last 19 years. In town, we’re down to 53 mpg.
  9. Mpdcnva
    Mpdcnva Member
    51
    27
    Washington dc
    Four Touring
    We used this tester.
  10. BiomedO1
    BiomedO1 Senior Member
    4,596
    2,411
    Left Coast
    This sounds like something floating around in your ATF got lodged someplace in your tranny and cause an alternate ground path. That threw your sensor out of tolerance and set the fault code. Now that it's dislodged itself, I'd change the ATF in hopes of removing whatever caused this issue in the first place. If your using something other than OEM ATF; I would switch back to it. The electrolytic properties of a 'compatible' ATF, may be what's throwing off your sensors.
    Just my 2 cents
    #10 BiomedO1, Sep 30, 2023
