Bad water pump P0A93 coolant loss in replacement process?
Discussion in 'Gen 2 Prius Main Forum' started by nancytheprius, Jun 28, 2024.
  1. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    Have lights on dash and code P0A93 from my techstream. Looked in the inverter coolant reservoir and no movement. Hoping to replace the pump this weekend. Will I lose all my coolant? How much can I expect to lose in this process? If I can get away with only purchasing one bottle I’d be happy (current coolant isn’t very old). Let me know thanks!
    2006 Prius with 121k miles
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
    Option 1, use "hose pinch off" pliers to squeeze both hoses shut before you take them off the old pump. You only lose a cup or so of coolant that way, and usually don't have problems with air in the system.
    Option 2, drain the inverter coolant into a (clean)pan before removing the pump - be sure to open the correct drain plug on the transmission. Refill and air bleed the system afterwards.
    Option 3, watch some people on youtube who do neither and make a mess spilling coolant all over the place.
    Brian1954 and nancytheprius like this.
  3. nancytheprius
    365
    157
    iowa
    Purchasing hose pinch pliers!! Just what I needed!!! Love this forum.
    Thank you
  4. ChapmanF
    19,006
    If I'm remembering the capacity of the inverter/transaxle coolant loop right, one bottle is plenty even if you lose it all.
    It's the engine coolant loop that takes more.
    However, comma, I don't have the capacity spec in front of me at the moment. Maybe look it up rather than taking my word for it.
    nancytheprius likes this.
  5. nancytheprius
    365
    157
    iowa
    Got it swapped in 2 hours with only wrenches. It’d be quicker with better tools
    Brian1954 likes this.
  6. pasadena_commut
    pasadena_commut Senior Member
    3,040
    943
    Southern California
