Bad wheel bearing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DrewG13, Feb 28, 2019.
  1. DrewG13
    DrewG13 Junior Member
    45
    New Jersey
    My 2013 has the brake, anti lock and ABS lights on. OBD says rr wheel anti lock sensor error, can't reset. I replaced this one 25k or so ago and just had my recall software updated and a new gel battery. Bad wheel bearing?
  2. ChapmanF
    18,982
    It's easy to read a little too much into the diagnostic codes. The computer in the car isn't all-seeing and all-knowing, so when it sets a code having to do with a sensor, that doesn't always mean the problem is in the sensor. It means the computer is suspicious of the reading it gets from the sensor, and that reading has to get from the sensor, through the wire harness and connectors, all the way to the computer input. It's up to the human to figure out where the actual problem is in that path. There will be helpful troubleshooting steps in the repair manual where that code is discussed.
    DrewG13 likes this.
  3. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Doubt it’s a bearing. I had one fail a couple years ago. No codes....just felt the drag, and noticeable MPG drop.
    Easy fix in my garage.
    Robert Holt and DrewG13 like this.
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Could be loose sensor plug
    Mendel Leisk and DrewG13 like this.
  5. DrewG13
    45
    New Jersey
    Thank you all for the input. I will check the manuel and the connection. I also need back brakes anyway so it will be an easy fix if it is the connector.
  6. padroo
    padroo Senior Member
    2,763
    2,253
    A visual inspection at the sensor and wiring where it is exposed to the harsh environment where it lives is a good starting point.
    DrewG13 likes this.
  7. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    For information: did the bearing either “howl” or generate grinding noises or any kind of roughness as it was failing?
  8. DrewG13
    45
    New Jersey
    Bearing isn't making any sound, I was thinking it was the internal sensor that was kicking the dash lights.
    Robert Holt likes this.
  9. DrewG13
    45
    New Jersey
    Voila problem solved, one of the pins broke off in the plug. Parts ordered here tomorrow. The people on this site are unbelievable.
    Jimi1976 and Raytheeagle like this.
  10. Jimi1976
    242
    124
    Denver, CO
    Yes.
    I drove it for a few months before repairing it....and on the last week or so it was humming
  11. Jimi1976
    242
    124
    Denver, CO
    And bob’s your uncle.....easy fix
  12. DrewG13
    45
    New Jersey
    Has anyone ever replaced the plug that attaches the bearing? The one I ordered has a connector and I couldn't see where that connector was?
  13. tankyuong
    1,555
    662
    Central MO
    You can solder it directly and silicone
  14. DrewG13
    45
    New Jersey
    What about using straight wire connectors and heat shrink?
  15. Mendel Leisk
    42,298
    Post a picture if you can. You'd almost need a macro lens though, pretty tiny. Those connectors are a pain, very difficult to pull off, and breakage prone.
  16. DrewG13
    45
    New Jersey
    I was talking about the wires not the pins.
  17. DrewG13
    45
    New Jersey
    Here is where the ABS wire harness connects on the right side that I had to replace. All fixed.
