Bait and switch?
Discussion in 'Gen 2 Prius Fuel Economy' started by sierrasig, Jul 10, 2008.
  1. sierrasig
    sierrasig New Member
    Davis, CA
    I just purchase a 2008 Prius (package 5) after waiting in line for a month for the car. I had rented a 2006 Prius from the dealer for several days to make sure I was really happy with the car and brought it home content. I had driven 200 miles of mixed highway and stop and go driving and used 4 gallons of gas (the indicator showed 48MPG).
    I have my new car and I am struggling to get 40MPG under the same circumstances, same settings etc.
    I note that unlike the rental, the car very rarely operates from the battery and also that the battery never fully recharges- it is at about 2/3 full.
    I called the dealer and he just said drive it 1000 miles and perhaps it will get better.
    Is there a chance that there is something different about the car- or is there something wrong with the first couple hundred miles driven?
  2. sleonardelli
    sleonardelli Junior Member
    141
    Ruskin Fl
    My mpg didn't really improve until I got my first oil change (synthetic) and had them increase the nitrogen in my tires (42/40). Check your tire pressure.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The dealer is correct. The battery should stay about 2/3rds charged, except under special circumstances. Likewise, your mileage will improve as you Prius breaks in. Give it a little time.
    Tom
  4. sierrasig
    Davis, CA
    thank you both for your suggestions! I will be less paranoid about the battery and will check with the dealer about the tire inflation. Patience.... never been good at that, but will work on it! ;)
  5. Godiva
    Godiva AmeriKan Citizen
    10,339
    There is a break in period. Just be patient.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Like stated above, give it some time.
    If you are truely worried I can stop by on my way home (I commute through Davis) and we can test drive it on the backroads I use for max milage. Road 27 and Pedrick Road work well for that sort of thing. :)
  7. PearlDriver
    PearlDriver Junior Member
    76
    Snohomish, WA
    Check the oil level and make sure defrosters are off.
  8. icarus
    icarus Senior Member
    4,884
    976
    earth
    Adjust the tire pressure as per Prius chat. Look in to grill blocking, even partially in warm climates/weather. I find that my car with the grill unblocked takes ~20 miles just to get to NORMAL temp, and the fuel mileage begins to go up. (In warm weather) With the grill blocked in cooler weather it still takes the 20 miles!
    Icarus
    PS. Buy a scan gauge here to monitor temps. You will see a direct link between temps and mpg!
  9. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Please check the mileage link in my signature. You will see that for the first, what, 9 months I never broke 50mpg. This summer I've already had one 71mpg tank and am currently working on my second. There is a break-in period: both for you and the car. Don't worry about it.
  10. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    most sales men are sharks and not to be trusted but the car itself is very sound and very well made.
    Relax. You bought the finest car made of it's type! at any price!
  11. kazots
    kazots LifesaBeach
    262
    CALIFORNIA
    Where do you get the prius chat sticker?
  12. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Don't worry! There is a break-in period for the car, too. Just as Tony said, you will learn how to drive better (for higher MPGs, that is) over time. Also, the car itself may require a break-in period.
    I noticed, for one, that my battery's State of Charge was consistently low for the first several weeks. I really was worried about this, but I notice that this changed, rather suddenly, after about 1,000 miles (maybe even less). I don't know what happened, but it just changed. My mileage increased a bit after that -- even though we were headed into a cool Fall season.
    I would take F8L up on the offer of having someone else (with F8L's experience and willingness) take a look at your car. If the two of you go out on his known route, you'll get a real fair comparison going. You also may learn a bit more about driving techniques for getting the MPGs up!
