Balancing Voltages Required?
Discussion in 'Gen 2 Prius Technical Discussion' started by jamber, Sep 1, 2020.
  1. jamber
    jamber Junior Member
    Ohio
    I'm currently reconditioning the modules in my pack. I was able to get some pretty good capacity increases on all the modules I fully reconditioned. Sadly I need to interrupt the process, which is taking a very long time for me as I only have one balancer, putting the battery back into the car and drive the car around. So I essentially have two questions:
    Is it okay to just pack the battery together and throw it in as-is? I'm currently charging all them to the same levels, but I'd like to skip this process.
    Would it be okay to drive around with only 6 of the modules reconditioned? I'm concerned about this because I only finished 6 of the modules and the ones after those 6 were pretty bad, so I'm predicting it the voltages will be largely different and cause fault codes. I'd like to plan to do a good amount of driving beyond simply moving the vehicle to my new residence. Before I took the battery out I already had drove the car over 5,000 miles with the master warning light going off every 15 minutes or so, I simply cleared the codes with my phone.
    49,372
    we can't really say, sometimes it works and sometimes it doesn't
    jamber likes this.
  3. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    and I would add it is not to be recommended, for the same reason you wouldn't just buy a brand new module and stick it in.
    All modules should have the same capacity otherwise it will be very unreliable.
    jamber likes this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
