Bartlett Corporation Leather on Ebay - $150!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by sl7vk, Apr 24, 2009.
  1. prius2go
    prius2go Member
    312
    The reason for starting with the back seats is
    a) you can still drive the car while working out what to do
    b) It's good practice
    c) If you dont get it quite right it's less noticable than the fronts
    d) after doing 200 hog rings/tie wraps you'll be relieved when doing the fronts.
    You do have to work out a plan of attack. When reassembling-the inner most hog wrings tie wraps first.
    For removal the original covers I didnt cut all the old hog rings. I unbent one end of the wire rod going through them then pulled the rod out from the other end. You can then decide whether to unbend all the old hog rings or leave them.
    There are loads of sharp metal edges - be very careful!
    The back of the rear seats is bad but you dont really have to get your fingers near them
    The front seats -you have to rotate the leather around the front edge which is just waiting to slice your hand off.
    Managed it ok - but be very aware.
    All the covers need cutting of the leather for inserting the headrest holders. Do this after youre sure you have the cover correctly in place and feel along the top edge for the hole in the seat back. Make a small hole first, you can feel through that with a small electrical screwdriver. Then carefully cut an X in the leather to the corners of the seat hole. The headrest holders can go in the wrong way & the headrests wont lock!
    4 people like this.
  2. jeteyenite
    jeteyenite Junior Member
    32
    PA
    I've done the rear seat and found 2 problems. One was already discussed here... the extra wire... I chose not to use the extra wire but use the plastric that was on the leather. Another problem I found was that there weren't any holes for the 2 hooks that are used to connect to the vehicle body. It wasn't bad... Just had to cut 2 places and let the hooks thru... :)
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    prius2go,
    Wow, your tips are invaluable, e.g.,
    -- Front Seat Side: Finding and removing that little front seat screw so that you don't break that one-way screw/clip.
    -- Carpet Clips: Your explanation of how upholsterers remove those molly type carpet screws with something akin to a BBQ fork to go in beneath the head to squeeze the screw's prongs; and your suggestion of using a knife instead to squeeze one side of the screw's prongs.
    -- Headrest Holder Holes: Fit the leather first, then carefully cut an X (not a big hole) ....
    The infrequent times I work on my car, I always find that I spend at least an equal amount of time trying to figure out those types of things, especially all the plastic screws, clips, tabs, etc. on the car, as I spend doing the real work.
  4. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    Anyone tackled the fabric that is to the side of the two rear seats?
    I'm scratching my head a little bit on how to attack these........
  5. tredstone
    tredstone New Member
    116
    Queens, NY
    Does anyone know how this leather compares with an OEM Prius leather seats? Just curious if anyone has had the opportunity to see/feel both to make a comparison.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Here are pics I took during the day (Saturday work) and the driver's seat (took 5 hours).
    I get to enjoy the leather seats starting from tomorrow!
      File size:
      72 KB
      2,358
      File size:
      24.2 KB
      2,335
      File size:
      35.8 KB
      2,335
      File size:
      96.5 KB
      2,345
      File size:
      80 KB
      2,364
      File size:
      92.4 KB
      2,330
    3 people like this.
  7. Boo
    5,051
    488
    97
    Flushing, NY
    Congrats usbseawolf. Looking good!
    Suggestions:
    1. Go back to the PriusHoods black leather center console cover?
    2. Consider getting black rubber or carpet mats like on the 2010 Prius Misty Gray interior?
  8. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    Never mind, I figured it out....
    Between a mad scramble to get this car done so that I can drive to work tomorrow, and getting a mothers day gift for my wife.... I made it!
    Only thing left is the door arm rests. I think that'll be for next weekend!
    What a ton of work. Whatever it is that they charge for this type of god awful work.... It's too little....
  9. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    Late night photo (pardon the flash) of the fabric section that is below the vent redone...l
    For those that have done, or are doing this.... I feel like I'm part of a blood order with you.... I think we've all seen things, and done things, we'd rather forget during this ordeal...... Only time will tell if it was worth it!
    2 people like this.
  10. Boo
    5,051
    488
    97
    Flushing, NY
    Congrats sl7vk!
  11. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    1) Yea, I too think the black center console cover looks better because they match with the black cup holders.
    2) I was planning to get the Canadian version of black all weather rubber mats. The current carpet mats went through 3 winters and they are quite dirty anyway.
  12. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Is there more than a screw at the bottom as shown in the PDF?
  13. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    That 12 mil screw is just the beginning.
    You then have to get the plastic cover off of the plastic skelton... Lots of broken clips in the process..... I mean lots.
  14. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    That sound scary.... Did you take any pictures how it looks after you take it off?
  15. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    GREAT JOB! Your back seat looks better than mine, but it's been rainy/cold here so mine needs some time to warm and shrink a bit. It's interesting that pictures show every tiny wrinkle, but in person they look fine. Plus even factory leather has a bit of wrinkling.
  16. PriusLewis
    1,002
    84
    Denver Metro
    That looks GREAT! Did you use 3M Upholstery adhesive? How did the stock cloth come off? And it will be worth it - the pain will dim but the leather will remain. This has got to add more to the resale of our cars than what we paid for the kits. One thing I've noticed is I'm much more protective of the leather since I have my own blood and sweat in the job - I'll be all over the grandkids to be careful back there!
  17. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    I used the equivalent to the 3M stuff in Generic from Joanne's.....
    The stock fabric came off easy peasy once the panel was unclipped. I'd recommend a small puddy knife to make it real easy.
  18. sl7vk
    sl7vk Member
    518
    23
    Salt Lake City
    I think I have some pics... They'll have to wait until tonight though...
  19. tredstone
    116
    Queens, NY
    How did you guys handle the door armrest?
  20. jeteyenite
    32
    PA
