Base/Touring Suspension - Real World Difference?
Discussion in 'Gen 2 Prius Technical Discussion' started by Mr Incredible, Oct 27, 2008.
  1. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Though I requested a Touring Pkg 5 (using the T word at least ten times while we were discussing the order), through an error of the sales guy writing the request we are getting a Standard Pkg 5 in early December. My inexperience with Prius not withstanding, I'd usually catch something like that pretty quickly.
    This car will be for Wife, with me picking up the tab. Wife wanted the zippy model. After much explanation of why, in the real world, the difference would be minor, she's still giving me That Look.
    She's acquiesced to the change, but my question is whether, in your-all's more experienced opinions, there really is a substantial difference between the feel of the different tire/suspension packages.
    Thanks for your time.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I'm sure you will get replies that the Touring gives a much better ride. However, I've driven both and really didn't see/feel much difference between them.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Touring does not make for a "zippy" model. The drive train, engine, and effective gearing are all the same. Touring gets you fancy wheels, better tires, and a stiffer (not better) ride. Whether a driver likes the stiffer ride of a touring model is strictly a matter of personal preference. Upgrade the tires on the standard model and it will be just fine. If you play the new tires properly, you may be able to placate your wife, or at least reduce the severity of "that look".
    Tom
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Hi Mr. Incredible,
    Welcome to PriusChat.
    Personally, if it were me, I wouldn't get anything other than a Touring. Two big reasons:
    1. Better handling - the Standard Prius handles poorly for a car of its size (175 inches long). With the Touring's bigger and wider tires (195/55/16), one inch larger stabilizer/sway bars and different rear shocks and springs, body roll should be reduced (the Standard Prius has more body roll than a lot of SUVs and minivans) and overall handling, including emergency handling (as noted by Consumer Reports), is improved.
    2. Better braking - the Standard Prius' braking distances rank it only in the 11th percentile of the more than 100 current model sedans tested by Consumer Reports. The Touring's 60-0 mph braking distances are 10 feet (dry) and 12 feet (wet) shorter than the Standard's.
    You can probably achieve these shorter braking distances by putting wider (195mm) and better tires on the Standard Prius. But that's $400 - $500 right there -- about the difference in price between a Touring Package 5 and a Standard Package 5.
    Anyways, if you haven't done so already, you might want to take a look at some of the previous relevant threads about the Touring. Here are the previous threads with the word "Touring" in the title:
    PriusChat Forums - Search Results
    Congrats and good luck.
  5. MR.K
    MR.K Junior Member
    86
    Idaho
    Many here have stated the larger 16 in wheels /wider tires knock mileage down & some have actually changed to the 15 in rims...I drove both ,I like the ride better on the non touring model ...as already stated the drive line is the same for both ....oh yea..the touring has a larger spoiler in back ,it has no effect on being zippy
  6. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    the problem with upgrading the standard prius's tires to something like the touring is you probably already spent half of what toyota sells the touring for and don't have any of the other stuff that comes with it. just the rims and tires is well worth 895.00 if you think about it. its practically like getting better suspension parts and the other spoiler for free.
    the only real downside of the touring is like i said over and over, your choices in the 195/55/r16 is going to be limited. depending on your area you might only have a choice between say a falken ze912 with tread life warranty for $99 a tire vs a michelin pilot primacy no tread life warranty for $135-$150 a tire, or the stock turanzas for $89-$110 a tire with no tread life warranty
    when the time comes and you do not like your choices of tires, you might get be forced to going run flat tires, or upgrading the touring to 205 55 r16s
    there are like 60 or more makes of tires in the standard prius size.
    it seems that the customer base of 195/55/r16 owners are 10 % prius touring owners and 90 % owners of cars that do not carry a spare
    also forgot to mention if you show off your touring wheels and rims, other base/standard prius owners will look at you all jealous and not even wave at you, fearing your car is better looking then theirs
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Mr Incredible,
    Uh Oh, The Look! This demands immediate action...
    There has been much lively discussion here on the meaningfulness of the
    relatively minor differences between the Standard and Touring models. The
    relevant OEM equipment differences have already been noted.
    As far as on-the-road, there has been mention that the Touring model may
    track better in cross-ways side winds. And, it has also been suggested that
    adding the after-market BT Stiffening Plate and maybe the BT Front Shock
    Tower Brace may minimize any such tendency in the Standard model.
    (Available from the PriusChat Store) Use the search function at the top of
    the page to see the threads on these items.
    So, even after putting the best face on your non-Touring purchase, if The
    Look persists, bestir yourself from where you've been sleeping on the couch,
    and know that there may still be ways for you to rescue a passing grade in
    Creditability-101.
    If/when you do have questions about the ride, handling, etc, don't hesitate
    too ask here, most folks are only too willing to help ... remembering that off
    in the wings we maintain a small group of cranks and curmudgeons as
    Old-School Subjective Reality Checkers.
  8. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    In my limited experience, if you had two Prius on the race track, one touring, one non-Touring, the Touring would lap a -little- faster due to higher cornering speeds. On the street, -I- don't feel any difference. I have a non-Touring because that is all that was available in 2007. This year in Canada, all that is available is the "Touring".
    Pearl, a 2007 non-Touring, corners as fast as I'm willing to go in the mountains, even when she wore the Goodyear Integrities. Due to the fact I don't want to go to jail and don't want to kill anyone. I grew up in the mountains in B.C. I drive faster than most on narrow mountain roads. I wanted a "touring", but now I don't really care. I put on Nokian WR tires and they made a huge difference/improvement.
    The difference between the two models is very subtle.
  9. Qlara
    Qlara New Member
    488
    I go for the non-Touring Prius because its 15" wheels will have more choices on tire brands than the Touring's 16" odd-ball size.
  10. Erin Rothchild-Realtor
    Erin Rothchild-Realtor Junior Member
    77
    Houston Area ~ Texas
    2014 Prius v wagon
    Im a 49 year old woman....my thoughts are and were that the safety features of stopping distances and the decrease of drifting on the highway are really important. Be the HERO and let your wife know her safety is the most important thing, not the approval of the salesperson who wants to sell "that" specific vehicle to you.
    In my quest for information about the differences between the base and the touring, I spoke with many Sales Managers and Service People who also did not know about the braking differences....and i learned it all right here, on Prius Chat...There is a wonderful resource of people, some are very factual, others have a sense of humor,and everything in between.
    Best Wishes Going Forward.....
  11. Mr Incredible
    955
    506
    Neb
    Erin, there's nothing I can do to make my wife a safer driver. She spent two years in Naples, Italy, and still drives like she's in Italy (complete with gestures and doubts about the parentage of other drivers). She has, however, stopped trying to make three lanes out of two. Most of the time...
    Having had much experience with putting different sized tires on the same car, I believe the differences between the standard and touring combos would be of little difference to the majority of drivers. A stouter suspension is always a plus, but again, I don't think on a Prius (which is hardly a performance platform) it wouldn't make a huge difference. Wandering has always been worse with wider tires in my experience in both my trucks and my Z28. Narrower tires don't follow the grooves and depressions nearly as bad, and the 10mm gap between the two is little more than a hard spit worth of difference.
    I looked up many tires on TireRack.Com (what a wonderful place to research tires). There are 22 choices for the touring tire. I wouldn't feel slighted with that much choice. After just buying new tires for my truck, the prices for car tires are CHEAP..
    In the end, the choice is hers. I'm not in a hurry to take on the payment and could wait forever. Her choices are to take the one in an agreeable color that will be here 12/4, or to wait an indeterminable time for a Touring Pkg5 to come along in one of the colors she can live with (only half of the available colors). There are two ahead of us for a Touring Pkg5, so that's another delay.
    I fully appreciate all the input. I knew there would be a lot, as that appears to be the default position here. :clap2:
    Thanks much for the info.
  12. Boo
    5,051
    483
    97
    Flushing, NY
    For what it's worth, I think the wandering is alleviated and the poor handling improved quite a bit by adding the BT Tech Strut Tower Brace ($250) and, to a lesser degree, the BT Tech Stiffening Plate ($165). I'm also thinking about adding a beefed up rear sway bar made by Premier for the 03-06 Corolla/Matrix ($95), which I understand fits the Gen II Prius perfectly.
    Regarding 10mm greater tire width, I think its impact on the wandering nature of the Prius is miniscule. But its impact on braking distances (especially if the tires are better too) can be significant. The Touring's 10 and 12 feet shorter braking distances are huge.
    Regarding the Touring tire size, I think about 3/4 of the 22 choices available are Run Flats.
    That explains it. No wonder you're getting That Look. She also probably can't eat pizza outside of Naples ever again. :)
    Good luck and congrats again.
  13. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Have a 07 Touring #5 and a 09 Touring Pak #3. Handleing is night vs. day. Ride is bumpier. Fog lights and VSC come with Touring. Wheels, tires, struts, shocks, swaybars would cost 3-4k additional if replacing those stock Prius parts. Get her some better rubber and think about stiffening up car with bigger sway bars. That should almost put you on equal ground with the Touring.
  14. Mr Incredible
    955
    506
    Neb
    Boo, a strut tower brace could be warranted. I'd have to "test drive" the thing and see how much of a pig it is. I'm not sure I could wrest it from her grasp until she goes to sleep one night.
    I didn't turn off the filter for runflats when I checked. Some of those could be in the pile, for sure.
    I'm not convinced 10 feet is huge braking difference. In actual driving on the street, not paying attention (NPA) can easily make it a moot point, with varying shades of NPA giving varying shades of mootness.
    Lastly, I have struggled mightily on putting together a pizza that can hang. I have been pronounced successful.
  15. Qlara
    Qlara New Member
    488
    If you look thoroughly from that 22 tire choices for the Prius Touring wheels, 3/4 of the tires are Run-Flat. And if you filter out the Extreme Summer and Winter Performance choices, you'll just down to 2 brands only...(where one of them is the O.E. Bridgestone) and the other is Firestone.
    Compare to the Standard Prius's 15" wheels, there are 29 tire choices if the same filter is applied from the Touring....
    I've no intention to use Run-Flat and Firestone tires, thus the choice is very limited to just the O.E. Bridgestone if Touring Prius is the car I have for new tires. Your preference is vary of course, but that's my point to pick the regular Prius instead of Touring.
