Basic code scanner?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cdgreg, May 29, 2017.
  1. Cdgreg
    Cdgreg Member
    Canandaigua, NY
    2020 Prius Prime
    I'm enjoying beginning DIY car maintenance on my '07 Prius and my wife's '09 Rav4. What do you all recommend as a basic code scanner reader that can also clear codes? I definitely do not need anything overly fancy, my goal is to be able to pull codes as they arise to then come on here/google to search and define the issue.
    There seems to be a range of options even within the cheap sector: $6 ELM327 OBD2 Bluetooth scanner on ebay, Mini VCI for $25 on Amazon, $70 Harbor Freight Deluxe OBDII Scan Tool Cen-Tech, and the $160 Scanguage II OBD + Digital Gauges kit offered here on Priuschat.
    Really just looking for something to identify code(s) and clear them. What do you recommend and what should I avoid?
  2. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    Try Carista. I've used it for modifying settings on my Prime.
    https://www.amazon.com/s/ref=nb_sb_ss_c_1_6?url=search-alias%3Daps&field-keywords=carista&sprefix=carist%2Caps%2C135&crid=35RGCC8X8T3Y0
