Basic maintenance an warranty
Discussion in 'Gen 3 Prius Main Forum' started by Anroga, Nov 23, 2017.
  1. Anroga
    Anroga Junior Member
    Puerto Rico
    Hi. I just bought a used 2014 Prius that is out of warranty but for the battery and related components. Will it void or affect my warranty to use non Toyota parts such as oil filters, air filters etc...? Thanks
  2. Mendel Leisk
    38,702
    If the engine warranty is expired I think it's not an issue. And likely not an issue while you're within warranty. Though oil filter I'm not 100% sure.
    Are Toyota parts not readlily available, or is this to save a few dollars? I've used nothing but Toyota parts (basically oil filters, have yet to change an air filter) and found them very dependable, regarding fit and quality.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You are asking a legal question, and I am not sure about Puerto Rico's legal system. If it is covered by US law, as it should be, the the Magnuson-Moss Warranty Act places the burden of proof on the manufacturer to prove you used inferior parts. You are assumed to have used equivalent parts in the US.
    "Warrantors cannot require that only branded parts be used with the product in order to retain the warranty." - Magnuson–Moss Warranty Act - Wikipedia
  4. Anroga
    Puerto Rico
    Thanks Mendel Leisk. Yes, Toyota parts are available. I just thought I might upgrade to more high end parts. Do you think it’s perhaps not worth it to upgrade?
  5. Mendel Leisk
    38,702
    Agree, not worth it. In particular, steer clear of reusable, oiled air filters, K&N and the like.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    There are no more high end parts, just high end advertising.
  7. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    I was about to say the same thing. Toyotas last a long, long time, because they are well designed and well made from well made parts.
