Battery 12 volt problem
Discussion in 'Gen 2 Prius Main Forum' started by matt71571, Apr 1, 2013.
  1. matt71571
    matt71571 New Member
    We t to start my prius this morning, and had to jump it. This is about the 4th time in a year. My battery is reading 11,7 volts do i need a new battery, or is something draining my battery. It is a 2008
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    Lot's of 12v replacement material on the site, look around, most replace with the Optima yellow top, the new model has the correct terminals to connect to the prius, the prior model needed to have some modification, it's a gel, deep cell battery, or you can buy an oem from the Toyota dealer.
    Taking the Mylar(covers the holes) off the one in your car, filling it with distilled water and trickle charging it for a day, will make it last a bit but as the motor is always charging a battery that won't quite take a charge, you'll be using more gas then necessary.
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    The Optima is not a gel battery, it's a spiral wound AGM lead acid battery.
    John (Btitprius)
  5. Britprius
    5,194
    1,914
    You do not say in your avatar where you are from, if your not in the US the Optima is not for you. As even the OEM poor as it is, is more realisticaly priced outside the US. There are other options.
    John (Britprius)
  6. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    There may be something draining your battery and you likely need a new one.
    If you have the smart key option, which I love, then it is drawing power searching for a key. This is not usually a problem unless the car is left unstarted for long periods, say a couple of weeks. In that case turning it off with the button under the steering wheel is best.
    But with this age, assuming it is the original battery, and the reported voltage reading, and the fact it has needed jumping 4 times now, it is most likely weakened to the point of needing replacement. With every jump you run the risk of connecting it in reverse resulting in very expensive damage. Better to replace the battery when and where you choose instead of the alternative. In that case you might find this thread interesting. Fitting mobility 12volt AGM battery. | PriusChat
  7. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
  8. Classic_pri
    Classic_pri Former 2001 Prius 0wner
    108
    27
    Wisconsin
    I got my Optima Yellow from Advance Auto. It lists at about $200 but the big box auto stores often offer large promotional discounts (20% or more) on their websites. I ended up paying about $150 plus tax.
  9. kenoarto
    396
    Chicago, IL
    Correction: some replace with Optima brand. Most replace with Toyota.
