Battery acid expire?
Discussion in 'Fred's House of Pancakes' started by George W, Jan 19, 2020.
  1. George W
    George W Senior Member
    934
    519
    San Antonio
    I have a golf cart that runs on six Trojan T-605 Batteries. Recently one of them failed hard, so I tested the gravity of the other five. One cell was completely flat, the other two cells were at 2.1 volts each.
    My father has an unopened box of battery acid from over 20 years ago, so I thought I might try to revive the flat cell. After adding acid the battery immediately responded and measured 6.2 volts across all 3 cells, but had not yet been charged. My charger is of slow capacity, so I know it will take several rounds to put energy back in that cell.
    After two rounds, the hydrometer is still not registering specific gravity.
    Am I approaching this with the wrong procedure? Does 20 + year old battery acid go bad? Thank you.
  2. Leadfoot J. McCoalroller
    8,261
    7,763
    Pennsylvania
    2018 Prius c
    No known expiration date, as long as it hasn't been mixed/polluted with other things in that timespan.
  3. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    When properly sealed, acids can be stored indefinitely. However, the chances of that for your 20+ year old container is low, so I would suspect your battery acid (sulfuric acid) may be the issue.
    Now, the acid doesn't "go bad" in the sense that it won't work. However, it may no longer be at the right concentration/pH to work effectively for your battery.
    George W likes this.
  4. Trollbait
    12,799
    Can't speak for battery acid, but solutions can have portions precipitate out over time. That and evaporation will change the concentration of it.
  5. bisco
    52,752
    i have the same problem, but will be buying 6 new batteries this spring, unless another solution works. how old are yours? mine are around 20 years.
  6. George W
    934
    519
    San Antonio
    Can't be sure of the age. I bought the cart 2nd hand, didn't even get 2 years out of them.
  7. Leadfoot J. McCoalroller
    8,261
    7,763
    Pennsylvania
    2018 Prius c
    We use the similar T-105 for power in our vacation home. The current ones are only 6-7 years old, but we've had some last as long as 20 years there.
    So far you're trying what I would try.
  8. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    You need to get the crud out of the battery plates if you hope to "revive" this cell or it'll fail again soon. There are several videos on YouTube on how to do this. You can even "re-use" your battery acid. But it looks pretty simple. Never tried it myself, but supposedly a couple guys at work have said they've done it. Worked for them or so they claimed.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes, wrong.
    No, acid generally doesn't go bad.....but 20 years is a LONG time.
    One does NOT rejuvenate a battery by adding fresh acid.
    That cell/battery is worn out. The plates probably are shorted out due to sulfation.
    It is not fixable.
  10. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Good point. Battery acid issues are only one source of failure. If there is any significant damage to the plates, then there is likely little you can do to regain sufficient performance.
    Quick list of battery failure points are here: Why Lead Acid Batteries Fail or Suffer Reduced Performance
  11. sam spade 2
    7,035
    2,804
    2017 Prius c
    Good link.
    But none of those points makes me think of a "battery acid issue".
    The only three "issues" with the electrolyte (acid) are:
    Loss from overcharging or being in a hot/dry environment too long.
    Specific gravity change due to being totally discharged. The fix for that is charging, NOT replacing the acid.
    Chemical changes due to sulfation removing some of the necessary ingredients.
    Those issues are not caused by the electrolyte (acid) itself but are symptoms of it being damaged by some other action.
  12. Trollbait
    12,799
    Some chargers have a mode that is intended to correct sulphation.
  13. George W
    934
    519
    San Antonio
    The only reason I thought the cell might be salvageable, is that its Voltage went from 0 to 2.0 volts after adding acid. After 3 slow-charge cycles it is still not registering any Specific Gravity, but still shows 2 V . It doesn't make sense, unless the acid is weak.
  14. Trollbait
    12,799
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    And if you really believe that.......I have some ocean front property for sale in Arizona. :ROFLMAO:
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    All "acid" is not the same.
    Battery acid from a discharged cell.....which is how it is shipped usually.....is a much lower specific gravity than when fully charged and has different chemical properties......somewhat.
    Chances are THAT cell is not charging and will not produce much if any current.
    I suspect that if you put a voltmeter on the battery it will read something around 12 volts......and the immediately drop by 2 volts if a load is applied.
    Summary: A bad, discharged battery (or cell) automatically means "weak" acid.
