Battery age
Discussion in 'Gen 3 Prius Technical Discussion' started by Willwortman, Aug 28, 2022.
  1. Willwortman
    Willwortman Junior Member
    25
    Gainesville, Florida
    Sorry if I just missed it but I cannot find a date decoder for this particular serial# config. It's a 2010 with 288,000 on the clock and I am trying to figure out if it is the original assembly before I crack it open. Every other serial # has either a letter at the beginning or multiple letters in the field.
    52,880
    you really do need to crack it open to see if any cells have been swapped
  3. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Date of manufacture is coded into serial numbers on each of the 28 modules. The outside cover doesn't offer that info.
    Tombukt2 likes this.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Check the car fax for any swaps. If none then it’s 12 or 13 years young.
  5. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    It is hard to test with any tools. Using Dr. PRius with a good ELF327 like Veepeak or Carista can tell the voltage fluctuation and internal resistance. At least you know it is still in a good range.
