Battery bus bars
Discussion in 'Gen 2 Prius Main Forum' started by Wrecit, Jun 25, 2022.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,249
    940
    Jack himself says go nickel plated.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,985
    929
    Southern California
    Plated with what and how thick? For the copper to corrode H2O, CO2, and O2 all need to reach the metal. If the plating is thick enough to start with, and not scratched or worn through, that should never happen. For instance, many battery cable connectors are nickel plated copper. They stay nice and shiny until they are mechanically abraded or too much battery acid hits them, at which point the green starts as the copper core starts to corrode.
  3. PriusCamper
    PriusCamper Senior Member
    13,353
    5,398
    Pacific Northwest, USA
    I clean all my bus bars by putting them in a rock tumbler for a day... It's fairly standard among hybrid battery rebuilders because it takes almost zero effort... And in all the batches I've tumbled the plating has never survived and was 100% gone after tumbling... And when you got jars of 500 bus bars, the plated ones that lost their plating look awful and end up in a jar where they're never gonna be used in a Prius again, but maybe for a DIY powerwall?
  4. PriusCamper
    13,353
    5,398
    Nope... Wrong on that one... But don't worry, it a minor amount of difference, @TMR-JWAP did the calculations on loss of wattage with plated ones. I'll dig up the link where we discussed the video if need be, but let's just start with video Jack did:
  5. PriusCamper
    13,353
    5,398
  6. pasadena_commut
    2,985
    929
    Southern California
    That video shows that the all the bus bars are the same electrically (for all practical purposes), but that flat bottom nuts provide a lower resistance connection than grooved bottom nuts. The nut bottom effect was about 40 times the size of the bus bar variation. Seems like the nickel plate would be worth it for increased protection from corrosion, unless there is a problem with the nuts loosening up on that surface over time.
    Prius Rising and VZvrtny like this.
  7. James Analytic
    409
    63
    Michigan
    So only use the bus bars in the rock tumbler with no other material?
    I've read four methods used so far:
    1. Aquarium fish rocks or sand in the tumbler after soaking in Vinegar to remove most corrosion.
    2. "run the corroded ones through the rock tumbler with a little bit of fish tank gravel and vinegar and they come out looking like new"
    3. " put them in the kids rock tumbler with medium grit and spin them 30 minutes and rinse them off and kerosene gasoline standard solution something"
    4. "Put them in a rock tumbler and add water and go to sleep. When you wake up in the morning take 'em out, rinse 'em off and you're done. They'll look brand new with a high quality matte finish."
    The later seems easiest. Wondering what is quickest, albeit with media will require a screen for the grit?
  8. PriusCamper
    13,353
    5,398
    Copper is very soft... I've done it with gravel and different grades of rock polishing grit too. But the copper is so soft there's no need for anything other than the bus bars themselves and some water.
    James Analytic likes this.
  9. Classic Car Guy
    Classic Car Guy Active Member
    501
    134
    Northwest, USA
    I'd give that old buss bar a major cleaning to "Baldor" the hardest working guy in the shop. You can slave drive him, you can have him working on weekends, you can always count on him without any complaints...:) upload_2026-2-25_11-50-31.jpeg
  10. James Analytic
    409
    63
    Michigan
    I prefer the wire wheel and do that to the modules and have in the past on the bus bars. The rock tumbler with water and fish tank gravel worked good enough.
    Now, a few weeks back I was looking into one of those solder pots to do a post cleaning dip tinning as that looks like the better long term cost effective route to do. $20-$30 is very tempting and looks like a good deal that still can be found just looking now.
