Battery charge program for prime - AGM?
Discussion in 'Prime Main Forum (2017-2022)' started by Professor Chaos, Apr 24, 2020.
  1. Mendel Leisk
    42,355
    Test it with an electronic load tester, such as Solar BA9. See what kind of Cold Cranking Amps it currently measures. If you don't want to shell out, most automotive retailers that sell batteries will a pro-level tester of that ilk, will usually do the test for free.
    (Sam, if you're commenting, I can't hear you.)
    Raytheeagle and Salamander_King like this.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    What exactly does that mean ??
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    From a post left by the person who STARTED this thread........and to whom my comment was intended.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    He means you are on his ignore list. ;)
    Rob43 and Raytheeagle like this.
  5. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Yes, a flooded cell lead acid battery, not an absorbent glass mat (AGM) lead acid battery. AGM's advantages are more durability to shocks and spill resistance...neither important for our cars.
    The electronically controlled battery chargers need some voltage to get them started. It doesn't take much.
    Is a new battery needed? Get the old one fully charged and drive to almost any place that sells car batteries. Ask for a free load test. That will show quickly if the battery has life left in it. The new battery needed would be a Group 140R, about $140 with free installation--if you go to the right place. That defines the size, shape, and terminal configuration. O'Reilly and NAPA have that size, among other stores. Some brands do not have this size. East Penn/DEKA might be the only U.S. battery maker who produces this size. The O'Reilly & the NAPA labeled batteries in this size are both DEKA.
    benagi, Rob43 and Mendel Leisk like this.
  6. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    I don’t know about other years but the 2020 manual says not to use higher than a 5 amp charger. Could the 10 amp cause a problem? The manual says the battery may explode if charged at a higher rate.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    If you were to leave it on for some ridiculous amount of time, anything is possible.
    But that's why a gave him the ~4 hour time limit.
    Rob43
  8. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Ok, thanks!
  9. Mendel Leisk
    42,355
    There are lots of charger options available, that are at-or-under the 5 amp limit. I do ignore some recommendations, for example my 2010 manual says to disconnect the battery before charging. I find that onerous, have never done that, and never had a problem. But staying within the max amp rating is easy, so why not stick with it.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Well, here are a few reasons why:
    1) First and foremost, the OP said his 12v battery was temporarily so dead that his brand new "the CTEK doesn't seem to recognize that there's a battery there" (Post #4). My experience with this is: You have to hit the nail with a BIG HAMMER to make it go in, meaning more amperage is needed to Force the battery into charging. Once the battery has been brought back to life by a dumb manual higher amp charger, something like the CTEK can finish the job.
    2) The other reason is this: Virtually every 5 or less amp charger that's readily available on the market today is a computer chip driven charger, just like the CTEK unit that failed the OP in the first place.
    Rob43
    Trollbait and Mendel Leisk like this.
  11. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Do you think it would be wise for him to remove the battery from the car before using the 10 amp charger?
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    Those characteristics aren't important in most vehicles.
    The important advantages are: Lower internal resistance (charges a bit faster) and highly resistant to sulfation, which is what kills most batteries and/or causes a loss of capacity. Thus they have a longer life and no need to check the "water" level.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    No it doesn't.
    It says not to actually charge it at a rate higher than 5 amps.
    Just because a charger has a higher max. charging capacity, does NOT mean that it will actually charge at that higher rate.
    Most of the time it won't even be close.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    NO. Absolutely not necessary.
  15. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    You are correct on both counts and I apologize for my sloppy quoting from the manual.
    However, if a battery is as "dead" as the OP's seems to be, wouldn't a 10 amp manual charger start out charging at higher than a 5 amp rate?
  16. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    Thanks, but I didn't ask if it was necessary, just if it would be wise.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes probably but it shouldn't last long......as in maybe 10 minutes or less.
    And it is highly likely that his battery is TOAST already so it shouldn't make much difference.
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    SIGH.
    NO, it is almost never "wise" to do something that is really not necessary.
    Every extra operation that you do is just another chance to screw something up.
  19. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    "Shouldn't" doesn't mean won't, right?
  20. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes. Major auto parts stores will perform a load test for free. Battery removal is necessary.
