Battery Charge Stacking while Parked
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CaliforniaBear, Dec 23, 2013.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Pollution control?
    52,801
    how does this thread 'stack up' against markabele's thread on losing charge while sitting?
  3. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    If the ICE stays off you use/lose charge. If the ICE comes on you gain charge, more if you stack, less if you don't.
    52,801
    i believe mark's was dropping while the ice was on.
  5. CaliforniaBear
    1,180
    289
    Northern California
    If SOC is higher than 75% it will drop to about that level if the ICE comes on.
  6. bisco
    52,801
    interesting! why is that?
  7. CaliforniaBear
    1,180
    289
    Northern California
    Something about keeping the SOC within its best continuous charge/discharge range as appropriate for HV operation. As I understand it HV continuous charge/discharge activity is best for the battery within 25% - 75% SOC. You are given that extra 10% (75 to 85) for the more occasional (1 or 2 or a few more times per day) for EV miles.
  8. bisco
    52,801
    now i have to go back to his thread to find out if his charge was above 75%.
  9. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    This situation is one in which my 'heater in a box' would be of help, I think. Two AC heaters running at 400 watts could maintain cabin temp in a non-moving car, I think.
  10. markabele
    5,084
    1,782
    Nebraska
    It was much less than 75% SOC. And yes, the range kept dropping while ICE was running (while sitting).
  11. bisco
    52,801
    so you and californiabear are having the opposite experience?
  12. markabele
    5,084
    1,782
    Nebraska
    And USB backed it up with real data from Torque.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    It depends on battery SOC. If it is above the comfortable level (70%?), ICE will not charge the battery (very little gas just to idle).
    If SOC is below that threshold, ICE will run at higher load and extra juice goes into battery.
    I believe this is the reason why warm ups in EV mode (normally above threshold) takes longer than if PiP warm up in HV mode (no EV miles left).
  14. bisco
    52,801
    i think this is what markabele is protesting in his thread.
  15. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    My understanding was that, his case was above the "comfortable" threshold. So ICE just idle to generate heat for cabin.
    His EV miles decreased because 500-700 watts (normal load) were consumed by car electronics (in Ready state). It would happen anyway if ICE and cabin heater were off.
    He started the thread because he thought ICE would generate electricity whenever it is on. Turns out, not the case.
  16. bisco
    52,801
    see his post #30 here. perhaps i'm mistaken, i'll let him respond.
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    We'll have to narrow down to what SOC (or other conditions?) that changes the behavior.
  18. markabele
    5,084
    1,782
    Nebraska
    You are correct.
    ICE was warm, I was well below 70%. Like you said, the ICE is running so low/efficiently that there just really isn't much there to charge with.
  19. bisco
    52,801
    if heat is a natural product of the combustion process, where does the rest of the energy go created by an idling engine?
  20. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Perhaps, It goes to maintain idling rev of the ICE.
    The same as manual tranny car idling unclutched at stop light.
    I visualize MG1 freely spinning as well. If there is a need for electricity, MG1 would create resistence to generate electricity. That would also put more load on the ICE and it'll use more gas to maintain idling.
    Would it be efficient? No, but it assigns more role to the existing hardware (ICE being heater). That helps reduce the overall weight and cost which in turn gain more opportunities for higher efficiency at other times. I see it as give and take balancing act, weighted by the frequency.
