Battery charger on lead-acid vs. AGM?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Caydoc, Jan 31, 2013.
  1. Caydoc
    Caydoc Junior Member
    32
    Savannah, GA
    ...just bought a CTEK 3300 charger/maintainer for my 2012 Prius, after seeing this brand and model mentioned favorably on this forum...the device's instructions emphasize it is to be used only for lead acid batteries, but I think our 12v is an AGM...can I use it safely? Thanks for an answer!
  2. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    Our 12v battery is lead-acid- but of AGM design which means it's low gassing and has a wet sponge type material (rather than sloshing liquid) between the lead plates.
    According to the 3rd bullet-point (under Product Features) at Amazon- it does support AGM batts:
    CTEK 3300
  3. Mendel Leisk
    42,347
    Geesh, I likely led you astray, never noticed that. I've used my CTEK 3300 on ours somewhere between 5 and 10 times. Never for a serious discharge so far, just as periodic top-up. Voltage seems to be staying steady, and no problems.
    I think ny-rob's right, that AGM is under the umbrella definition of lead-acid battery.
