Battery Charger
Discussion in 'Gen 2 Prius Technical Discussion' started by DeekoPete, Jan 20, 2008.
  1. richard schumacher
    7,683
    1,066
    United States
    ?? How do you manage to do that with a Prius?
  2. tom_farr
    tom_farr New Member
    SoCal
    Does the Prius need only enough juice to boot the computers? If so, would one of those little solar panels be enough to start a dead car? (in the daylight, of course ;)
  3. BigJay
    BigJay reh reh REH reh Torture them!
    2,937
    554
    DFW
    I've only had the Prius for two weeks now. I imagine I will continue to lock my keys in the wife's mini-van though.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Not enough amps, unless you get a big one or live on the sun.
    Tom
  5. sideyt
    sideyt Junior Member
    Re: Battery Charger and Preventing Sulfation
    I heartily recommend everyone check out the small but effective BMW charger which does the job and prevents battery sulfation (which is really what you are trying to do - keep the battery condition optimal - not have pumps and other "extras").
    Enough said..
  6. darelldd
    6,059
    389
    Northern CA
    Oh my god. Who the hell does that, and why? I've been jumping cars for 30+ years, and have never had the urge to do that.
  7. darelldd
    6,059
    389
    Northern CA
    Not *quite* enough said. Got a link?
  8. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Wow, you are the first person I've heard of jumping another car from the Prius. I'm really surprised it worked w/o blowing anything up! I think the fuse in the dc:dc converter is only rated at 100A if I remember right, and I wouldn't think the little battery in the Prius would be good for much more than that either.
    Rob
  9. patsparks
    10,664
    569
    Adelaide South Australia
    When using jumper cables you MUST make the last connection a negative connection and you must make it away from the battery. Never make the last connection anywhere near the battery, especially near the dead battery which may have just had a high discharge from trying to start the car. A high charge or discharge will cause a release of hydrogen and oxygen gas, so don't connect a cable which completes a circuit in the gas cloud. Hydrogen burns very well especially with extra oxygen around.
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    You'd be surprised how many folks do that. When I had a company truck to drive, I offered to jump start an older guy at a parking lot once. I made the mistake of not checking up on him while I hooked up the cables on my end
    I assumed he was following the accepted hookup sequence. I turned around to see him holding the two cables, which he touched to make a spark. So I asked him Wth are you doing?
    "Oh, just making sure we have a connection"
    There was no damage to the truck but I've always been leery of offering help. With the jump start box, if it fries that at most I'm out around $90
  11. Doc Willie
    1,717
    144
    Out there, somewhere
    Here's an interesting problem I may be facing:
    I would like to have the Zhang Heng indoors for display, with the lights and sound running. In my experience, this will drain the 12 v battery in 1 - 2 hours.
    How would I hook up an external 12v supply (probably powered from wall current) to have things running indefinitely?
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Just get yourself a "battery tender" (Batterytender.com - Home of All Your Charging Needs). It comes with a cable you can permanently install to the fuse box under the hood, and plug in/out as needed. Get the larger unit (3 Amp as I recall), and it should be able to power your "stuff" without draining the battery. The battery tender won't overcharge the car and won't damage the electronics.
