Battery Computer
Discussion in 'Gen 2 Prius Technical Discussion' started by Matthew Tucker, Nov 19, 2020.
  1. Matthew Tucker
    Matthew Tucker New Member
    Mount Vernon
    When I attempt to start there is clicking from Battery Control module.
    I have replaced 4 cells and the battery control module
    any idea idea what's going on or how to fix?
    thanks in advance and help would be appreciated
    I have a 2007 Prius
  2. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    The relays make clicking sounds on start up, which are normal... If possible compare your Prius start up sounds to another Prius that you know is healthy.
    Do you have any warning lights/error codes?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Your battery is still jacked up. You replaced cells and don’t have Techstream or any capable obd reader? Thats a classic whack a mole there. Rebuilding the battery and No obd code reader is pretty silly as you can clearly see now.
    Measure the dc voltage across the battery side of the relay with safety plug in and see what the pack is putting out. Should be at least 215
    Did the battery ecu plugs and sockets look clean and did you take the ecu circuit board out of the metal can and check it?
  4. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    It is probably worth going over the obvious. When you reinstated the HV battery safety interlock, did you do all three steps (as shown below) – i. e. in step 3 sliding the handle all the way down until it clicks?
    PriusCamper and strawbrad like this.
  5. PriusCamper
    13,411
    5,413
    #1 most common last goof before high voltage success.
