Battery Cool-Down Before Charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilofsky, Jul 22, 2012.
  1. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    After driving the PiP, how long should one wait before recharging it?
    And why isn't there a delay option in the charge timer?
    Sometimes I put the timer on, let it sit a while, and then use the Entune app to start charging. But don't know how long a wait is long enough.
  2. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    16
    Racine, Wisconsin
    I'm curious why you think there must be a delay at all?
    52,889
    i suppose you shouldn't charge warm batteries, but id i have somewhere to go, i just throw it back on charge. granted, it doesn't happen on a regular basis.
  4. gbrown
    gbrown New Member
    58
    LA
    Car won't charge if batteries are in an environmental condition outside of the parameters...so plug in as normal and let the car decide.
    priuskitty likes this.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    thank you!
  6. drees
    drees Senior Member
    1,782
    247
    If you're worried about battery life, the best charging strategy is to have the car just finish charging right before you go and drive it. Of course, making this happen in real life is easier said than done if you want to charge more than once a day.
  7. gbrown
    gbrown New Member
    58
    LA
    the only concern I have and avoid is letting the car, fully charged, sit in the sun.
  8. markabele
    5,084
    1,782
    Nebraska
    I don't think it's as big of worry in the PiP as it would be in the Leaf since the PiP doesn't let you charge to 100%.
  9. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    I
    The Leaf doesn't either. Although it does let you charge to 93% I believe, which I still think that is too much.
    Glad to hear the PiP won't let charging start while temps are too high. I was very surprised the Leaf doesn't have a sensor set up to prevent charging while too warm. It is a pretty basic bit of software/hardware I would think.
  10. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The "cold soak" helps with longevity. Batteries like to rest, rather than being recharged immediately after having just been depleted. It's not necessary. But if there's the opportunity, take advantage of it with the timer or Entune.
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    do you have data to back up this "theory?"
  12. markabele
    5,084
    1,782
    Nebraska
    Not that I don't believe you, but where did you read that? I've always read it goes to 100%.
  13. john1701a
    12,840
    5,312
    58
    That came from Toyota itself, during the PHV reveal last September.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    got the link to that article?
  15. drees
    drees Senior Member
    1,782
    247
    "Resting" only helps lithium batteries in that it potentially allows them to cool off and allows them to spend more time at a lower SOC - both of which reduce inevitable capacity degradation.
    What Nissan calls "100%" is only about 93-94% full. Nissan lets you use almost 90% of total capacity of the pack - a bit more than 21 kWh out of 24 kWh when the pack is new. Of course, they recommend that you use the "80%" "long-life" charge mode, don't leave the car sitting at "100%" for long periods of time, and don't constantly top off the battery back to "100%".
    Allowing the end-user to charge to a true 100% SOC would today's common lithium chemistries would quickly result in capacity degradation leaving usable capacity than by limiting max SOC to something lower.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  17. drees
    drees Senior Member
    1,782
    247
    What specifically are you referring to?
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    all of it. I see a lot of explaining, but no facts or articles to back it up
  19. drees
    drees Senior Member
    1,782
    247
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
