Battery cooling fan location?
Discussion in 'Generation 1 Prius Discussion' started by beth524, Aug 16, 2017.
  1. beth524
    beth524 Junior Member
    66
    Ithaca, NY
    2001 Prius
    I got a code p3007 on my 2002 Prius, and have been reading that the hybrid battery cooling fan may need to be cleaned or possibly replaced. I have not found any info on where this is located, how to test it, or how to clean it. I am also wondering if you ever hear this fan running? In the 15 years I have had the car, I am unaware of any "fan sound" coming from the battery. The hybrid battery was replaced around 65,000 miles, and I now have 120,000.
    Thanks for any help and insight!
  2. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Its on the driver hand side of the trunk. You will have to pull back the trunk liner to get to it. There is black plastic ducting that it connects to between the fresh air intake and the battery It is pretty easy to get to and remove.
    beth524 likes this.
  3. boostedsil40
    boostedsil40 Junior Member
    24
    AZ
    2002 Prius
    so is this for the HV or the regular 12v?
    52,863
