Battery Corrosion, Traction Control, Motor Lagging, ABS...
Discussion in 'Gen 2 Prius Main Forum' started by yvairguy, May 10, 2022.
  1. yvairguy
    yvairguy Junior Member
    I had an account here before but for some reason I can't seem to find or resurrect that old account. I've worked on a few other prius for myself and for a couple friends.
    I bought a project, for the right price, but a project nonetheless.
    2008 Prius with 177K miles. When I first bought the car the dash didn't work but I had no idea there were so many other issues with this car. I checked it for codes and it had none, but it has sat with a dead 12v battery and they could have been cleared, through all this and about a month of driving it has not thrown one code and there is nothing pending. Except when it Christmas treed the dash and I found a corroded battery.
    When it gets to around 30 it seems to shudder when it's trying to switch from electric to gas(ICE) only. Sometimes it drives just great with no issues and other times it feels like the traction control is trying to trigger or the ICE isn't coming on quick enough or it's running rough.
    When I bought it there was a set of plugs on the floorboard and a new air filter. When I was installing those I noticed that someone had installed a Mass air flow sensor. So it's obvious that there were issues that someone was already trying to figure out.
    It seemed to like the new parts but was still acting weird with the shuddering and it also had a set of miss matched take off tires, all the same size just all different brands. So I was hoping that maybe the ABS or traction control wasn't liking the used tires and put a new set on... it still runs great at times and then has issues.
    Last week it gave me the Christmas tree of death.... I said great it's probably just been the battery all along. It has a "rebuilt" battery with 10,000 miles on it. I pulled the battery and it was covered with corrosion. All modules were within .2 volts of each other and they all read around 7.8 volts. I cleaned and reinstalled the battery, I forced a full charge and it's still doing the shuddering thing.
    At times it seems like it is slipping like a regular automatic transmission would, but anyone that has driven a Prius on snow... it also sometimes feels like the traction control is triggering but not showing the warning on the dash. After I cleaned the traction battery and was really accelerating hard, it was doing the shuddering thing again, only this one time the traction control warning light came on so I'm wondering if it's a wheel sensor issue and this was the only time it's triggered the warning light.
    I'm kind of at a loss. Transmission? The fluid was dark but no chunks and not very metallic looking. ICE issues? The oil was clean and after an oil change and about 1200 miles it's still pretty clean for a Prius with 177K miles.
  2. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    What region of the US do you live in? Perhaps you live near one of us and we can help more than online?
    In general you've got all kinds of symptoms and the more we know about the error codes those symptoms create the better. Toyota Techstream on an old Windows machine is the most thorough. But spending $15 on an OBD2 like this one: Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Code Reader Check Engine ... | eBay and using phone apps for error codes is way easier.
  3. JahT
    JahT Member
    145
    77
    When you say "doing the shuddering thing", do you mean at idle the engine rattles, maybe not every time, and if you give it a little throttle or put it in "N" it stops shaking?
  4. yvairguy
    That one of the problems, this care has too many problems to just put a finger on the one issue.
    I ordered techstream with cable from amazon, first one came with a cracked disk and I tried to find a downloadable version while amazon sent a replacement... all the online versions or techstream had viruses as did the second item from amazon.
    I have a OBD2 tool and I have used it on other prius and this care is showing no codes or pending codes save for when it through up the christmas tree. since I have cleaned up the battery it is almost half full or better, before I cleaned the battery it would go down to one or two bars.
    I am in Southern California near palm springs.
  5. yvairguy
    Shuddering feels more like it is cutting power while running. It will actually shake you back and forth, though slightly, in the seat. It feels a lot like when the traction control is triggered and it cuts power, like when you are on ice.
  6. yvairguy
    Wow this form used to be much more active. Where is everybody gone?
  7. bisco
    52,848
  8. PriusCamper
    13,455
    5,430
    The smartest among us drive electric cars now... And after 20 years the work on this website is mostly done. Any symptom you have, anything you need fixed, it's all explained on here and you just have to Google your way to the answers.
    What apps have you tried to use with OBD2 tool to read error codes? Maybe your OBD2 is bad? Try another one, as they aren't expensive. For example: Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Code Reader Check Engine ... | eBay
    Can you make a list of all the issues/problems you've had with the car?
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    If you think it might be traction control, then disable it and see how it drives. You can download the Dr Prius app for your smartphone and (most) OBD2 bluetooth adapters. In "special features" it has a function to disable T/C for the current ignition cycle. Or you could unplug a wheel speed sensor.
    Other possible causes of shuddering on accel could be engine misfire - that usually causes a rattle as well from the transmission damper. Depending on the severity of a miss, you can get P030x codes in the ECM, or at least misfire counts in mode$06 data.
    Another possibilty is that there is a shorted winding in one of the motors. Gotta look in the service manual for testing procedures. I think I read that one test you can do involves disconnecting the motor leads from the inverter and measuring the windings using a good MILLI-ohm meter.
    Another test (with motor leads disconnected) was to use jumper wires to short all 3 leads for a motor together then slowly rotate that motor. (Disable the "park" system while the car is in neutral then push the car on a level surface to check MG2. Use the crank pulley bolt to rotate the ICE while in park - or wheels blocked/ parking brake on- to check MG1.) A shorted motor causes a big change in turning resistance.
    I have found the Autel Maxi AP200 bluetooth device ($70) and app to have very good codes and data functions on all ecu's on a Gen2 Prius.
  10. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    Unlikely given the professed vows of poverty many on the forum routinely make.
  11. mech1222
    mech1222 Junior Member
    32
    usa
  12. bisco
    52,848
    the rich ones already left
  13. Another
    1,819
    520
    Naples, Florida
    Both of them?
    NOLA_Akita and bisco like this.
  14. bisco
    52,848
    we have had quite a few tell us they were moving on to tesla, and likely many that didn't bother to post it here.
    a study from a couple of years ago showed more people jumped from prius to tesla than any other model.
    and that makes sense, since so many early prius adopters were tree huggers
  15. Another
    1,819
    520
    Naples, Florida
    Tesla is a urban or suburban car at best. And overpriced one at that. Musk is a marketing genius.
    NOLA_Akita likes this.
  16. mech1222
    32
    usa
    cmon man you dont wanna stop and charge every 200 miles or so? you get to chat with all the other tesla drivers charging also...
  17. yvairguy
    Thanks for all the replies. I had to go out of town for a couple weeks but your suggestions will help when I return.
