Battery dead after front brake job
Discussion in 'Gen 3 Prius Main Forum' started by Barrett Partington, Nov 3, 2021.
  1. Barrett Partington
    Barrett Partington New Member
    Maryland
    I just replaced the right front brake and rotor on my 2011 Prius following the nutz and bolts technique. Everything seemed awesome after reconnecting the battery. Drove up and down the driveway. Then parked it the garage. But when I returned to go pick up the kids the battery was dead and there were strange noises coming from the engine compartment. many help would be great!
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    A couple of questions:
    1. Why did you change, only the R/F caliper and pads? Rust?
    2. Did you displace any brake fluid (bleeder or brake line)?
    3. Fluid level check?
    The way is sounds, your brake accumulator may be running none stop. This can be a sign that the brake accumulator has failed (???) and is bypassing fluid internally. If it can’t build pressure it will just run continuously.
    Montgomery likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    How do the brakes feel? Check the fluid. If it's emtpy, maybe you didn't tighten a connection,
    or left the bleeder valve open a little.
    Perhaps the caliper itself is defective and leaking?
    Since you only did the one, I would check that first, before charging the 12v battery(unless
    you are going to leave it disconnected).
    And if there is a leak, fix it first before connecting the battery.
    You'll have to fill the brake resivoir first, and please the caliper. HOPEFULLY, it didn't cause any
    damage the to accumilator or motor.
  4. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    +1 very strange to just change one side of the front brake rotors. Definitely should be done in pairs.
    How old was the battery? Maybe it's just bad timing, and the battery was going to fail anyway.
    Tombukt2 likes this.
  5. OptimusPriustus
    OptimusPriustus Active Member
    338
    144
    Finland
    I have not watched the referred video. Does it instruct to bleed fluid out from bleeder valve when pushing the pistons in? Many times pistons are just pushed in and excess fluid is sucked out from reservoir. Thats not good thing.
  6. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Are you sure the battery is dead? Did it go into READY mode when you tried to get the kids? What kind of strange sounds you hearing under the hood?
  7. SteveSco
    SteveSco Junior Member
    uk
    Sounds like the 12v battery is dead. Charge it up and test it.
    Tackle one fault at a time, once it's starting, check for noise.
