Battery Dead?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MikeyK, Mar 26, 2016.
Tags:
  1. MikeyK
    MikeyK New Member
    Oklahoma City
    Ok, the car will not start, or even allow for unlocking of the doors. It makes a whining sound, and the lights only sort of come on. WHAT is going on, and what can be done?
  2. working1
    working1 Active Member
    121
    111
    Definitely replace the 12V if it's the original in a 2010. Long over due. All types of oddities occur in a Prius with bad 12V.
    Ninjawife likes this.
  3. JC91006
    16,482
    8,400
    In any car, when the car doesn't start, you should look at the battery first.
    49,482
    welcome! open your drivers door with the mechanical key. pop the hood, and test the voltage at the jump point.
  5. MikeyK
    MikeyK New Member
    Oklahoma City
    If we could get to it, we would do so. That is one of the issues we are facing is that we can not get to the 12v
  6. bisco
    49,482
    no prob, just hook a 12v to the jump point under the hood, and everything works, including your hatch.(y)
    if thats too much trouble, crawl into the hatch, pull the lid off the manual pull wire and open manually. see your o/m for details.
  7. MikeyK
    MikeyK New Member
    Oklahoma City
    Thank you!
  8. Mendel Leisk
    38,723
    That's ONE big improvement with the 2016: pop the hood and there's your battery.
    m.wynn likes this.
