Battery disconnect?
Discussion in 'Gen 2 Prius Main Forum' started by marlowe7, Apr 8, 2011.
  1. rogerdpack
    rogerdpack Junior Member
    82
    Enoch, UT
    Oddly, the manual I saw said to actually disconnect the cable from the battery terminal (not from the cable from the body like everybody does LOL). It seems to never say to disconnect the positive cable...even though it has those convenient connector clips that might tempt me... :) So I guess all those sparks disconnecting the negative are...OK?
  2. ChapmanF
    19,020
    People have been disconnecting cables from battery terminals since forever, because cars forever ago usually didn't have a nice plug-in connector you could just unplug.
    And everybody learned the safety reason to disconnect at the − post first and reconnect there last (in any negative-ground car) because if your wrench bonks between the − post and the body metal nothing serious happens, and once the − post is disconnected you can do the same at the + post and wrench bonks there won't cause any trouble either. But if you go wrenching on the + post and the − post is still cabled to the body, and you bonk the wrench, you end up branding your hand with the wrench logo.
    Happily, when there's a nice fully-sheathed plastic plug-in connector at one of the posts (doesn't matter which one), you can just squeeze that and unplug it and you're done. If all you want is to power down the car.
    If you're going to proceed to take the battery out, then yes, you still have to undo the clamps on the posts, and yes, it still matters to undo − first and reconnect it last.
  3. Allen.z
    Allen.z New Member
    Hong Kong
    I've gone up to 3 weeks without starting the car with no problems.
    52,854
    it just depends on the health of the battery, the ambient temperature and the draw the car has when off.
    it's a gamble, not always worth taking.
  5. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    A battery maintainer is your best bet. But make sure it's the type that will stay on after a power failure.
    I use the NOCO Genius 5. I don't recommends trickle chargers.
    I used one for the winter, and by spring the battery was completely destroyed.
    It's a crap-shoot. I've learned that the hard way.
    If you're in the USA, Princess Auto = Harbor Freight.
    #25 Paul Gregory, Sep 26, 2025
  6. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Also a crap shoot.
  7. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I have had good luck with products made in China for the most part.
    Well worth the price advantage, which is often 10% of domestic.
  8. VelvetFoot
    1,408
    545
    New York State
    2026 Prius
    Well, everything is made in China these days. It's the no-name aspect that concerns me. I suppose you always have to look at the possible consequences of a product failing, like getting maimed from a tool failure or a garage/house burning down. Price is a powerful siren call though. I have plenty of Harbor Freight stuff.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    Everything made in China is bespoke to the client, who can be from any country.
    If you want quality, they will produce quality. Nearly every brand is made in China.
    If you specify a cheap price, they will do their best to build to that price.
    If you are a scammer, making a scam product, to them, you are just another client.
    It's easy to blame them, but that's how business is done.
  10. bisco
    52,854
    some clients are chinese
