Battery drains while parked under the hot sun
Discussion in 'Gen 3 Prius Main Forum' started by Heat Gun, May 17, 2014.
  1. DrPepperholik
    DrPepperholik Active Member
    342
    109
    Spartanburg, South Carolina
    Yes, it does have solar roof. It's been rainy and overcast here lately but today is supposed to be sunny I believe. I will make note of my observations for a couple of days and update later.
  2. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    We spent a lot of time in Florida last year... really hot humid 90s daily down there, cooling fan ran all the time while parked... never saw battery drops of any sort. Even while parked for 2-3 days.
    In urban and suburban driving, our Prius was maintaining 61+ mpg, the best I've seen for a prolonged period (ended up with a tank to tank calculated 58.3 mpg). "Cold" tire pressures 40 psi front, 38 rear. Prius had about 32-33k miles at that point.
  3. Former Member 68813
    3,524
    983
    US
    Sounds like the car is not completely turned off. Maybe a weird malfunction of a relay?
  4. WE0H
    WE0H Senior Member
    3,247
    528
    I know mine was powered down. Doubt anything would be wrong with 1500 miles ;) I'll do some tests this season when I get a chance to take it out of storage. I did buy license tabs so I have to drive it at some point this season or my wife won't be too happy :)
    Mike [​IMG]
  5. fuzzy1
    10,685
    It is under some floor dress panel, but it is actually in the cabin interior. We have had a few prior cases where cars parked in hot sun all day had restricted battery operation -- e.g. no EV, no auto-shutoff of ICE when it normally should, poor acceleration and mpg -- that was remedied once enough cabin AC had been pushed through the battery.
    Yes, this will help with diagnosis.
    It is supposed to be disconnected. In OPs case, it seems that this is a possible trouble spot to be checked out.
  6. stoby9
    stoby9 Junior Member
    23
    16
    Austin, TX
    Interesting post. I've never noticed a huge drop like the OP is describing, but in the first 1500 miles or so I did notice a consistent 2 bar drop whether the car was left overnight (relatively cool) or while I was parked at work during the day (relatively hot). Since then I've made it a habit to use as much of the battery as I can in the 2 miles between the Highway and my house (or office). If I leave it at 2 or 3 bars it never shows different when I return.
    In the end the issue is likely an inaccuracy in the more full readings that corrects itself after the car has cooled down and been restarted.
  7. Heat Gun
    Heat Gun Junior Member
    56
    Los Angeles, California
    I've been doing some tests and trying to figure out what is really happening, I can't say for sure I am still working on it but I guess battery drains IF AC is on right before I turn-off the car.
    For past three days I parked car under hot sun many times, if AC was off before park then battery remains the same, If AC was on then I see significant drop, please dont ask if I am sure car is completely turn-off :)
    I will keep testing for next few days
    WE0H likes this.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    Wonder if it is runnin the A/C or maybe a software bug ;) I will take my car out of storage in July or maybe the last week of June and do some testing too :)
    Mike
  9. DrPepperholik
    342
    109
    Here's my little update now that we've had some nice (non-rainy) weather. I have noticed once that it seemed the battery was drained a little between the morning and lunch time on an exceptionally hot day, 91 degrees. Then from lunch to quitting time it was fine. I'm going to keep testing it and see.
  10. Heat Gun
    56
    Can you test with ac/on and off?
  11. DrPepperholik
    342
    109
    Sure. Just to clarify you mean something like this: Run AC and leave the switch in on position then turn off the car when parked as usual. By AC off don't run the AC and make sure the switch is in the off position before turning off the car when parking. Did I understand you correctly?
    Edit to add: I'm going to don my white lab coat (I actually have one from my pharmacy technician days in college) and make sure to account for the biggest variable, weather. I'll toss a small notepad in the car and jot down the temperature, sunny/cloudy and number of dashes (ticks, slots, whatever they're called) on the battery and AC on/off. That should give a good set of results.
    #31 DrPepperholik, May 30, 2014
    WE0H likes this.
  12. Troy Heagy
    Troy Heagy Member
    1,218
    I leave my windows open.
  13. Heat Gun
    56
    I've updated the first post, thank you folks
  14. Former Member 68813
    3,524
    983
    US
    Thanks for the update. Things like that turn to be user errors.
    I did some crazy things too when I was new to prius. Like stepping out of car, noticing it's still on and in drive, and chasing it.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    Good thing it is so slow!:eek:
    Heat Gun and WE0H like this.
  16. stoby9
    23
    16
    Austin, TX
    Interesting....my mileage seemed to pop-up right around 3K miles as well (and with no change in driving behavior).
  17. Heat Gun
    56
    I think Prius engine breaks in around 3k then.
  18. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    I'm glad your 2014 Prius is OK now.
    :oops:A door stayed open or a dome light on could have been the cause!!;)
    Thanks for the update.:)
