Battery Dying Too Soon / SOLUTION
Discussion in 'Prime Main Forum (2017-2022)' started by Rob43, Apr 23, 2019.
  1. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Another option would be to put a solar panel on the dash when you park. You'd lose some light through the windshield, but I expect it would still work. You could store the panel in the gap between the passenger seat and the center console while not in use. I propose referring to that gap as "the filing cabinet".
    jerrymildred likes this.
  2. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    You could get a Battery Tender brand solar panel which is regulated to prevent overcharging.
    There is some level of current that you can continuously apply that won't overcharge a battery, but it's probably around 20mA for this size battery, for the battery itself. And of course there's the parasitic draw but that's probably another 20mA. I think 1/3 amp would be a little too much without some kind of regulation.
    jb in NE likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I didn't realize they make a solar controller now. The price isn't too bad, either at $28. Of course, if you live in CA, this thing will kill you immediately from the cancer-causing stuff in it, but the rest of us have no worries.
    021-1162
  4. m8547
    m8547 Senior Member
    951
    631
    Colorado
    2018 Prius Prime
    Or the all-in-one solution. It's a little expensive, but I'm thinking of putting one in my other car that doesn't get driven much.
    021-1163
  5. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    One moment it's not effective,.....the next moment it's overcharging.
    LOL, which one is it ?
    Rob43
  6. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I guess it's both. If it does get some sun and generate useful output, what prevents it from overcharging the battery?
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Buy it / buy something & you figure it out.
    Rob43
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    I will pass. No battery problems on mine.
  9. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I don't understand the problem. Is the 12V not holding charge and the car is not starting? Time to replace it with a Yellowtop!
    Nope, not by a long shot. Far too close to the ground and will never be facing the sun except a sunrise/set and then only if the car is pointing east/west. He'd be better off slapping it on the hood when the car isn't being driven.
    I'll answer even though it is rhetorical ;) You get more power from a horizontal array on cloudy days than one that is pointed directly at the sun. In places where it is cloudy most of the time (like apparently Glasgow, Scotland) the calcs for proper angle get thrown out the window.
  10. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    What you can't see in my pics is that my panel is mounted upward at roughly a ~78 degree angle, thus improving it's efficiency.
    So far I'm seeing an improvement in battery voltage.
    Rob43
  11. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Nope, looks pretty darn vertical to me. Even well more vertical than my panels are in the winter at latitude 45°
  12. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Nope back at you, it's mounted at roughly ~78 degrees.
    Rob43
  13. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Guess we need a side shot ;) In any case, per schedule, I adjusted my 2 ground mount arrays to 17° today. My most vertical angle is 64°, at your latitude summer would be 8° and winter 55°. You really would be better off with it laying on the hood.
  14. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    I performed a little test tonight with my voltmeter on my solar panel to make sure the blocking diode is working properly.
    Gladly it is working correctly, here's a good explanation I grabbed off goggle.
    "Blocking diodes are used to prevent your batteries from discharging backwards through your solar panels at night. ... As a result, in the days before charge controllers, people would put a blocking diode in series between the battery and the solar panel, only allowing power to go into the battery."
    Rob43
  15. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    His comments are perfectly valid......and your snotty reply is NOT.
    AND......since you have never responded to post #4, I assume that you are just trolling and trying to stir up trouble. You should find better things to do.
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    OK,
    Thanks for your opinion. (y)
    Rob43
  17. schja01
    schja01 Senior Member
    1,855
    1,229
    Chicagoland
    2024 Prius
    Limited AWD-e
    Let me see it after it goes through a car wash. :)
    kevin.c likes this.
  18. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Yeah, that could be a problem...
    Rob43
  19. CharlesH
    2,797
    1,165
    Roseville, CA
    Yep. All of the things driven by engine belt in a conventional ICE car, such as A/C and power steering, are electric in the Prius. Some, such as the A/C, run on on high voltage AC generated off the high voltage battery by an inverter, and others run on 12V generated off the high voltage battery by the DC-DC converter. In the first generation Prius (2001-2003), the A/C was driven off of an engine belt, so if you were sitting at a light, the engine had to turn on if you needed A/C, which was a real bummer, as I recall.
