Battery electrolyte proton transport
Discussion in 'Environmental Discussion' started by bwilson4web, Jan 29, 2019.
  1. bwilson4web
    16,524
    The premise of this article is proton, hydrogen ions, are an efficient transport: Proton transport 'highway' may pave way to better high-power batteries
    Here's how it works: Electrical charge is conducted when a hydrogen atom bridging two water molecules "switches its allegiance" from one molecule to the other, Wu explains.
    "The switch kicks disjointed one of the hydrogen atoms that was covalently bonded in the second molecule, triggering a chain of similar displacements throughout the hydrogen-bonding network," he said. "The motion is like a Newton's cradle: Correlated local displacements lead to the long-range transport of protons, which is very different from metal-ion conduction in liquid electrolytes, where solvated ions diffuse long distances individually in the vehicular manner."
    Added Ji: "The cooperative vibrations of hydrogen bonding and hydrogen-oxygen covalent bonds virtually hand off a proton from one end of a chain of water molecules to the other end with no mass transfer inside the water chain."
    I did not realize that protons have no mass. Sorry for the snark but this was a sad mistake.
    The transport of ions through the electrolyte is what makes a battery work. There is merit in using the smallest ion, hydrogen protons. However, there remains a major problem of what happens to the volume of the cathode and anode. With rare exception, there is a tendency for the electrode volumes to change and that poses a serious mechanical problem. So they state the obvious:
    . . . Right now the battery community focuses on lithium, sodium, and other metal ions, but protons are probably the most intriguing charge carriers with vast unknown potentials to realize."
    There is one example, NiMH batteries that store hydrogen in the metal hydride matrix.
  2. tochatihu
    tochatihu Senior Member
    9,964
    3,847
    Kunming Yunnan China
    2001 Prius
    First seemed vaguely odd. Techexplore description was clear though.
    This is water interacting with solid surfaces. We must set aside thoughts of pure water conducting electricity (by passing protons) which it does not. Pure water (with ~micromolar concentrations of H+ and OH-) is a good electrical insulator. Put things in it (any things, really) and it becomes conductive.
    bwilson4web likes this.
  3. fuzzy1
    10,694
    That isn't how I read the item.
    I see it more analogous to describing proton 'holes' moving along a medium, where no single mass moves the whole distance, but a very large number of particles move a tiny increment. Though the article goes farther by referencing Newton's cradle, where the intermediary particles don't move at all, but just transfer the forces or properties that cause the end particles to move.
    Whether or not the description is accurate, it isn't equivalent to claiming that protons are massless.
