Battery for 2010 prius
Discussion in 'Prius v Main Forum' started by Dontez, Jan 1, 2017.
  1. Dontez
    Dontez New Member
    San Antonio
    Hey guys I have a 2010 Prius in the auxiliary 12 V battery went bad and I'm told that I have to buy the new one at Toyota why can I just buy a 12 V battery at the local auto parts store thanks
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    It is a special type of battery (AGM) that most cars don't have. A few auto parts store chains do have this type of battery in stock. Pep Boys is where I bought the one for my 2005 Gen 2 in 2012.
    So you might not have to buy a new one at a Toyota stealership. Depends on what's available in the Metro San Antonio area.
    sam sami and Dontez like this.
  3. Air_Boss
    Air_Boss Senior Member
    4,262
    1,197
    New Yawk
    No reason whatsoever, unless you want and are willing to pay a premium for whatever additional warranty coverage a dealership may claim to offer. 12V battery replacement is a DIY job. Just make sure to get the correct size/format/capacity 12V aux battery.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    Here is one auto parts store with the battery. I believe my son ordered his Gen 2 battery from Amazon.
    EDIT: Oops. Apparently I did not paste my AutoZone link. Is is more expensive anyway for the same battery.
    #4 Prodigyplace, Jan 1, 2017
    Dontez likes this.
  5. Mendel Leisk
    42,386
    I would not rule out the dealership parts department without at least checking price and availability. Their battery will for sure be exact fit, and I believe the warranty is pretty good now?
    That said, there are aftermarket options. In Canada Canadian Tire sells a Motomaster battery (rebadged Exide) that is dimensionally identical, proper vent port and post size. There's also an Optima Yellow Top battery (the kind that look like a six pack), again: correct dimensions, etcetera. Both of these options (the Motomaster in particular) are cheaper, and have higher Cranking Amp ratings. I went with the Optima about 16 months back, next time I might try the Motomaster.
    Here's some notes:
    OEM battery info (measurements taken directly):
    Battery id: S46B24R GS YUASA
    length: 9 3/8" (238 mm)
    width: 4 7/8" (124 mm)
    height: 8" (203 mm) (plus posts)
    post dia's:
    Pos: 13 mm (approx)
    Neg: 10 mm (approx
    Weight: 310
    Optima Yellow Top:
    Group Size: GR#51JIS: 46B24R
    CCA: 450
    CA: 575
    Length: 9.272 in
    Width: 5.024 in
    Height: 8.885 in
    web page:
    Canada Tire alternative:
    MotoMaster Eliminator Ultra model 10-5122 (rebadged Exide battery)
    Above Canadian Tire battery is rebadged:
    Exide FP-AGM51JIS
    Bosch Premium Performance Battery Group Size 51
    Part # 51-440BAGM
  6. Dontez
    Dontez New Member
    San Antonio
    Thank you so much I will look into that!
  7. Dontez
    Dontez New Member
    San Antonio
    Thank you so much you are the greatest!
  8. Prodigyplace
    12,720
    11,852
    Central Virginia
    Ummm I believe Canadian Tire is Canada only, although they are a great store chain. O/P is in Texas.
  9. Mendel Leisk
    42,386
    Yes, I'm aware of OP's location.
    I note their battery is a rebadged Exide. It's a pretty typical example too: automotive chain store sells rebadged batteries at lower price. Costco's Kirkland brand, for another example.
    Prodigyplace likes this.
  10. Mendel Leisk
    42,386
    Hey sorry if I came off snippy.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    Not at all.
    I used to shop at Canadian Tire all the time, including for fuel when I was in Toronto Canada in the 70s.
  12. Joe-G
    Joe-G Member
    243
    99
    Ft. Lauderdale, FL
    I've been using a $35 riding lawn mower battery for months. The price of the 12v batteries for our cars is highway robbery.
    milkman44 likes this.
  13. Mendel Leisk
    42,386
    Before and after my switch to Optima. I had to put one washer under a bracket connection (location id'd by arrow). The bracket's a very fussy design, doesn't adopt to even the slightest variations.
    OEM:
    (I highlighted the + and - symbols with silver marker: otherwise they're hard to see.)
    Optima (a little blurry):
  14. jadziasman
    1,355
    488
    District 6
    I hope you're not a smoker, joe because if the battery you bought is not vented to the outside and you smoke your Prius might go up in smoke someday. Not worth the savings by a long shot.
  15. mikefocke
    4,083
    1,865
    Sanford, NC
    CCA is not an important spec as the 12v doesn't actually start the ICE engine so it doesn't need the power that a normal ICE car battery would, It only starts the electrics and runs accessories. And after the electronic controls start the traction battery takes over to start the ICE.
  16. Mendel Leisk
    42,386
    Maybe though a battery with higher Cranking Amps is also better at enduring phantom loads, if the car's sitting periodically for 2~3 days between uses? Or recover from an accidental drain? I'm not sure, just speculating.
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    The Optima Yellow is supposed to be better at deep cycling than the typical lead-acid battery, I believe.
    The Optima Yellow is an AGM battery.
    AGMs are built to better stand up to repeated draining and recharging cycles than standard batteries. They are becoming standard equipment in more cars because modern features such as fuel-saving stop-start systems, electronic safety and convenience features, and power outlets for mobile electronics all increase the demand for power.
    From Best Car Battery Buying Guide - Consumer Reports
  18. milkman44
    milkman44 Active Member
    591
    386
    Ky
  19. bisco
    52,923
    what's wrong with getting a battery at the dealer? quick, simple, effective.
  20. milkman44
    591
    386
    Ky
    $200
