Battery for 2010 prius
Discussion in 'Prius v Main Forum' started by Dontez, Jan 1, 2017.
  1. Mendel Leisk
    42,317
    I'm using iPhone too, and not any App, just Safari. One thing I've found, the Upload a File Pop-Up is quirky, to the point of being buggy. There's a nice big button saying "Choose File", that works just fine on a PC, but does squat on an iPhone. To get the file open dialogue going on iPhone you have to click on the text above, "Upload a File".
    The above was posted via a pc btw, just to facilitate mark up. I took the pic on phone, then emailed to myself. On a windows pc, release 7 or higher, it's very easy to do screen grabs via the snipping tool, annotate, and whatever you have is automatically in Clipboard (on-deck for pasting). If you have something in Clipboard while doing initial post (or when doing "advanced editting" when editting), <ctrl> V will paste it wherever the cursor is. Very handy, don't have to use the file load dialogue.
    BTW, the odd button behaviour on iPhone has been the situation for donkey years. Cleanmpg (another site, using same software) seems to have left things as-is much more, and there the pop-up dialogue button works fine on an iPhone.
    Maybe @Danny can look into this, it's been like this maybe a year?
  2. Prodigyplace
    12,711
    11,848
    Central Virginia
    I usually email the picture to myself & use a PC to post.
  3. ChapmanF
    19,001
    You may choose it any way you like, but if you're paying attention to how a Prius works, you soon realize the reason the car specs (at the end of the New Car Features Manual) give an amp-hour capacity for the battery, instead of giving any cranking-amps figure, is because the aux battery in a Prius doesn't crank anything, and to choose a battery with the thin plates optimized for cranking would be to sacrifice durability for no benefit.
    -Chap
  4. repnatl
    repnatl Junior Member
    49
    24
    US
    An autozone yellow too optima for a mid to late 90's civic will work.
  5. Prodigyplace
    12,711
    11,848
    Central Virginia
    And less expensive from Amazon as stated above.
    repnatl likes this.
  6. Mendel Leisk
    42,317
    Best deal for me in Canada was through SaskBattery. No shipping charge and 6% less tax. Amazon was just working with them, also free shipping, but I think the full 12% tax. The Amazon purchase (and return policy) is more streamlined though, I'm a big fan.
    Still, next time I'll likely go with a local retailer (Canadian Tire for me): they have the rebadged Exide readily available, local, and about $30 cheaper.
    Prodigyplace likes this.
  7. Air_Boss
    Air_Boss Senior Member
    4,254
    1,195
    New Yawk
    That's why I chose an Optima Yellow. YMMV
  8. Mendel Leisk
    42,317
    That's what I have. It does indicate fairly high CCA, comparative to the OEM Yuasa (I think, hard to even find CCA stat for the Yuasa). But you're saying regardless, it's fairly robust?
  9. Prodigyplace
    12,711
    11,848
    Central Virginia
    From the photo attached here, I do not think it is AGM. Notice the Explosive Gases warning.
  10. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Thanks for taking the time to do this.
    Interesting. Same amp hour rating as the Gen 2 and 3 aux battery.
  11. Air_Boss
    4,254
    1,195
    New Yawk
    Yes, I have found them to be 'fairly robust' in this and other applications. The size 51R fits the Prius, the CR-V and the 2000 Roadster.
  12. Mendel Leisk
    42,317
    Thanks for that, I'll save a copy. Exposed caps too, seems that would facilitate a electrolyte top-up with distilled water.
    PDF copy attached:
  13. Prodigyplace
    12,711
    11,848
    Central Virginia
    Close, it is a 2017 Trim Two.
  14. sam sami
    sam sami New Member
    sweden
    2000 Prius
    great
  15. sam sami
    sam sami New Member
    sweden
    2000 Prius
    hi!
    can you check this error in prius 2000 ...i have upload a video by which you can hear a noise in it prius - Sendvid
  16. bisco
    52,819
    sounds like a fan belt.
