Battery fully charged for 1st time...only showing 19.4 miles of range?
Discussion in 'Prime Technical Discussion' started by Banksy, Apr 3, 2021.
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    From empty, yes
    8A? Where do I check that?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I was thinking the same. Factoring in the time it spends tapering off the charge near the top, this is probably about the right ratio.
    Page 123 in my manual. However, if you don't know how to change it, it's unlikely to have been changed. Unless maybe the dealer did it so he could charge it on an outlet that was also in use by other stuff.
    @Salamander_King:
    I programmed my schedule over two years ago, as soon as I got the car, so I don't remember what it said without a schedule. With a schedule, it gives the time of the next charge and offers the "charge now" option if you hit that button.
    I can't find any references in the manual as to what is displayed if there is no charging schedule. I guess someone without a schedule would have to tell us or someone would have to volunteer to delete their schedule, check on it, and then reenter the schedule. :(
    #22 jerrymildred, Apr 11, 2021
  3. Banksy
    415
    132
    I will check this and report back
    Very interesting 2nd charge though
    Went from 19.5 miles
    To 24.4 miles
    jerrymildred and Tideland Prius like this.
  4. Banksy
    415
    132
    Looks as if it's set to max
    Tideland Prius and jerrymildred like this.
  5. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Did you have the car set to climate prep? That can add a lot of time to the charging when using 120V.
    jerrymildred likes this.
  6. Banksy
    415
    132
    What is that and how do I check it?
  7. PiPLosAngeles
    1,551
    724
    The car can be set to warm/cool the car before your scheduled departure time. The problem comes from the strategy the car uses to do that when connected to 120V. On my 2018 (I haven't tested the 2021 in this regard), it will get near the end of the charge and then use the traction battery to heat/cool the car, which means it needs another 15 or 30 minutes to charge back to 100%. By that time the heating/cooling is mostly lost and the whole thing was an exercise in futility.
  8. Banksy
    415
    132
    Didn't see that exactly
    But I did see this
    Not too sure if that's the same thing or not but I turned it OFF
    I should note I have no charging times set
    #28 Banksy, Apr 11, 2021
  9. jerrymildred
    11,517
    14,152
    Tampa, FL
    Not the same thing. You probably should leave that on since it can get pretty cold up there. Having it on means that if it's cold when you shut down it'll ask you if you want the car to heat the traction battery before it charges it. If you don't have that on, it won't ask and you could find yourself charging a battery that's colder than it should be. Professor John Kelly explains the heater starting near the beginning of this video.
    Climate prep is for the climate in your cabin. And it's as thoughtlessly programmed as @Salamander_King claims (as is the battery heater, since it should always be enabled so you can decide for yourself). Even with L2 charging which could easily run the HVAC while charging the battery, the cabin temperature has reverted to its previous level before the battery finishes charging because it stops charging while it's running the HVAC.
    Salamander_King likes this.
  10. Banksy
    415
    132
    So how do I turn it off or check because I didn't see an option for it
    There has to be a reason this is taking so long to charge lol
  11. PiPLosAngeles
    1,551
    724
    While it's charging, what does the display show when you open the driver's door?
  12. Banksy
    415
    132
    No
    I really haven't also looked at any of the displays while it's charging
  13. PiPLosAngeles
    1,551
    724
    Try it. Just open the driver's door whiles it's charging and take a look.
  14. Banksy
    415
    132
    Will do
  15. Hicksite
    Hicksite Member
    176
    2020 Prius Prime
    If there is no charge schedule set, it will display next charging event: charge when next plugged in. (Somewhat paraphrased.)
    I believe this is the message the OP was seeing and it is totally normal, although the first time I noticed it I was freaked out until I figured out what it was actually saying!
    #35 Hicksite, Apr 12, 2021
    jerrymildred and Salamander_King like this.
  16. Banksy
    415
    132
    There is no charging event
    When the door is open this is all that comes up
    Under scheduled events when I try to add one I see that option as being off by default
    With that being said what does this all mean?
  17. PiPLosAngeles
    1,551
    724
    I was wanting to see what it says when you first plug in on an empty battery. It should say something in the neighborhood of 5.5 hours.
  18. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    Mine always displayed 6hr 10min when I plugged in after depleting the EV range, but it probably took less than 6 hours to complete the charge.
  19. PiPLosAngeles
    1,551
    724
    I'm wondering if there's a voltage issue at work, or old wiring/outlet with higher than normal resistance.
    OptimalPrime and jerrymildred like this.
