Battery has range, but doesnt work properly.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shimano Teryaki, Mar 3, 2026.
  1. Cornvalue
    Cornvalue New Member
    24
    Internet
    Business Ed. Plus
    I am not saying dr Prius is wrong. It’s just that its focus is only the battery OBD values. It is not the full story.
  2. Shimano Teryaki
    Shimano Teryaki New Member
    Poland
    Update:
    it turns out its most likely because the new battery is a lithium - ion battery while it should be acid battery. didnt know that you can put a different type of battery in a certain car. I called previous owner and this battery in fact is a lithium ion battery. For now i dont have money to replace the battery but when i will keep observing the situation and when i solve it, i will post update for people looking for solution in the future.
  3. indel
    indel Member
    283
    89
    Northwest Indiana
    If you have a lithium battery, it's after market and Toyota won't be able to do any diagnosis on it. Even when you decide to replace it with OEM Toyota battery, you will need to eat the core charge because Toyota won't accept the Lithium battery as core.
  4. Mendel Leisk
    42,379
    That's a bad sign.
  5. bisco
    52,904
    Where did they get it from?
    There are some companies supplying lithium for nimh Prius, and you could call for support.
    If they simply replaced the modules with lithium, you might be driving a fire hazard
