Battery icon never solid on '17
Discussion in 'Gen 4 Prius Main Forum' started by dslomer64, Jun 16, 2017.
  1. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I've never seen a solid battery icon. Top level is always empty, not filled in.
    This "full" condition was rare in my '06, but it would happen on long hills, for example. But it's been 6+ months and I haven't noticed '17 being "full" yet.
    Is the never-full situation at all alarming?
    Gen 2 (2006) and Gen 4 (2017)
  2. Tyfly
    Tyfly Member
    65
    94
    Mine has never been full since I purchased it 2 months ago. I'm guessing that is normal.
    dslomer64 and That_Prius_Car like this.
  3. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    The less than full 8 bars indicates there is still capacity left in the battery. It takes a longer down hill to fully charge the HV battery. You don't need to worry.
    dslomer64 likes this.
    52,848
    my gen 2 used to go to full bars on a flat highway under the right circumstances. while full was fairly rare, it happened way more often than every 6 months, and i'm a flatlander. perhaps gen 4 is programmed to use more battery.
    i also wonder if there is a difference between gen 4 nimh and lion.
    kithmo likes this.
  5. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You may be onto something there bisco. Although I don't often go down any long hills, I did once have the Prius+ (v) , which had a Li-Ion battery, max out the battery meter once but never the Gen 3 or now the Gen 4, both NiMh.
    dslomer64 and bisco like this.
  6. Mendel Leisk
    42,343
    Our 2010 will go to full bars very occasionally, with a long enough hill.
  7. fuzzy1
    10,706
    It depends on what your 'long hills' are. If it is a 7 mile 7% grade, then something is wrong. If it is a 2-3% grade, then it is likely that nothing is wrong, regardless of length.
    Numerous Gen3 owners in flatter regions, rarely or never see the top battery bar. I don't live and travel in such a region, so I've topped out as many as five times in a single day.
  8. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Yes, the gen III and 4 use the battery more than the gen II. I've never seen full bars on Pearl S, and did see them occasionally on Pearl on "flat land". Find a long hill and see if you can get to full bars.
    It's normal, whatever "normal" means.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've seen it only twice - once at the bottom of a 600 metre mountain road, the other after a 3 or 5 km drive down 7% - both with it at 7 bars to start with. Highway driving it goes between 5 and 7 bars, city between 2 and 7 bars.
  10. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    I notice that the Gen 4 seems to go into engine braking mode more easily than on my Gen2 and seems less likely to get all 8 bars, but it does occasionally.
    kevin
  11. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    On both my gen3 and current gen4 saw the full battery very very rarely, typically only after a very long steep hill. And I live in a hilly/mountain area...
    Gen4 though seems to charge it faster than Gen3.
  12. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I have noticed that also. I see a "full" battery display occasionally in my Gen 4, but not as often in the Gen 2 or Gen 3.
  13. raspy
    raspy Senior Member
    438
    699
    London, UK
  14. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    In 8 months, I've had full bars probably 2-3 dozen times. Long downhills in California highways make it very possible. And mountain downhills fill it easily.
  15. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    I actually got a full battery icon yesterday for the first time coming down Mount Scott (Wichita Mountains National Wildlife Refuge in SW Oklahoma) in the B shift position. I had never used the B shift position before.
  16. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    I got one of the two green bars on my '06 just driving 30 miles over very flat terrain in Cincinnati, which, by the way, has 7 hills (a la Rome; hence the name, from Cincinnatus... And now you know...), none of which we were near.
  17. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    I have it probably once every two or three weeks, 16 three with ATP, Lion battery. I live in Florida and drive a pretty long stretch of road to go to the next major city over approx 10+ miles and when hitting a light not using DRCC, it will often max out the battery indicator. I usually try to burn off some excess charge in my battery so this doesn't happen and have to throw away all that regen in the friction brakes.
  18. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    Its extremely rare for mine to fill 100% up. Nothing to worry about.
    RCO likes this.
  19. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Woo hoo. I-71 from Cincinnati to Louisville is hilly and the road from the Owenton, KY edit is almost all downhill and curvy with speed limit suddenly dropping from 55 to 35. Downhill plus brakes for nearly a mile = full battery icon. Lasted all of ten seconds, but saw it.
  20. kevinwhite
    333
    200
    Los Gatos Ca
    If the battery ever fills up it means that any further regeneration is thrown away either by engine braking or friction braking.
    It is not a good thing if it fills up!
    I find that mine fills up too easily, when driving down the Santa Cruz mountains my Spark EV used to reclaim a couple of kWh of energy, the Prius quickly fills up then goes into engine braking.
    kevin
