Battery issue? (video included)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Stephan Jefferson, Sep 20, 2019.
  1. Stephan Jefferson
    Stephan Jefferson New Member
    Long Beach, CA
    2012 Prius Four with 61,000 miles. I have had this car for about 3 weeks and I suddenly had issues starting it (see attached video).
    After about 5 minutes it ended up starting and now two days later there's still no issue. My question is should I get a new battery from the dealer to avoid being stranded and potentially having to get it towed?
  2. Stephan Jefferson
    Long Beach, CA
    Video won't upload but the dash kept flickering. Should I go to dealership and purchase another since it has been starting 2 days consistently since the event?
    52,790
    are you going to diy?
    52,790
    if not, you need to have it tested
    otherwise, you may spend a lot of money unnecessarily
  5. Stephan Jefferson
    Long Beach, CA
    Yes I was going to do it myself.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    A flickering dash board can be caused by a weak/discharged 12v battery. It would be worth your time to have the battery tested. If it's the original 12v battery, it might even be worth just replacing for peace of mind, especially if you have a wife/kids that will be using the car. But, you could of course temper that with real test results.
    Stephan Jefferson likes this.
  7. Stephan Jefferson
    Long Beach, CA
    Yes it is the original battery and I drive 60 miles a week picking up and dropping off my daughter. The battery is roughly $200 from Toyota dealership.
    You're quite wise
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_O
  9. Stephan Jefferson
    Long Beach, CA
    What am I doing wrong when trying up upload a video? I kept getting an error saying something about the format not being supported. I tried converting it to several formats but still nothing and it is a video that I took from my phone
  10. Stephan Jefferson
    Long Beach, CA
    Ok the car did it again. Couldn't even use the normal open the door and had to use a physical key. Wouldn't start or power on. After few minutes it just worked as normal.
    I tested the battery last night and it appears to be working properly. Any suggestions? Will replacing the 12v fix the problem? Or put it be the hybrid battery?
  11. bisco
    52,790
    either replace it or have it tested at an auto parts store. it most likely is the 12v, just replaced my 2012.
    or buy a volt meter, very handy to have. have we discussed fob batteries?
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    11.9v and it’s working properly?
    o_O
  13. Stephan Jefferson
    Long Beach, CA
    The fob was blinking red. Do you think it could be as simple as that? Even when I used The physical key and got in the vehicle it still wouldn't start right away.
  14. Stephan Jefferson
    Long Beach, CA
    Correct. but that test was last night and it wouldn't start this morning. Not sure if that makes a difference.
  15. bisco
    52,790
    red = good, but if you haven't changed them, you should.
    if it won't start with the fob held up to the power button, it is likely the 12v
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    A working 12v battery for a Prius should be measured at 12.7v or higher after overnight. Anything lower than 12.7v will give you issues down the road, including loss of MPGs, issues with unlocking doors, even turn over to ready state.
  17. bisco
    52,790
    if you don't want to spend 200, check pep boys, et al
  18. Mendel Leisk
    42,285
    Checking the battery with the car's display is pretty iffy. It's showing only voltage, and that voltage may be dragged down by various loads. If you were to measure 11.9 volts, first thing in the morning, with the car off, with a decent digital volt meter, that would indicate a near-dead battery.
    The simplest effective and cheapest route for you is probably to get an automotive retailer (say Pep Boys) do to a gratis battery test. Or DIY, look into something like Solar BA9.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Voltage is low enough to let you know it’s time to replace. I don’t believe in using those battery maintainers if you drive every other day. 12v Batteries are not needed to be put on a charger maintainer if car is driven on a regular basis. Get a new battery and do away with car headaches.
  20. Mendel Leisk
    42,285
    I do believe in battery maintainer, but then: our car regularly sits for 3~4 days, and then we might just be going on a grocery run.
    edc415 likes this.
