Battery issues on 05 prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Khaja, Dec 15, 2013.
  1. Khaja
    Khaja New Member
    I keep having to jump start my 05 prius what does this mean? Is it time for a new battery?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Probably time for a new 12 volt battery. They're about £100/$150 and are located in the rear under the floor.
    They usually have a life of 6 years or 80,000 miles/130,000km, so if you're over those figures on your original, then you've done well.
  3. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    It is not a good idea to keep jump starting the Prius. One wrong connection can do a lot of expensive damage. Replace the 12 volt battery now.
    John (Britprius)
  4. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yep, get a new 12V battery as soon as possible. Be real careful with your jump starts, you'd be amazed how many people come here complaining about a 4 digit repair bill after they fry the inverter with a failed jump!
  5. Takeshi_Ito
    Takeshi_Ito New Member
    CA
    Totally agree. Jump starting is not advisable, a simple mistake could cost you a lot. Have your battery replaced immediately.
  6. Valerie Cali
    Valerie Cali New Member
    Thought my battery was dead, even jumped started it correctly, then deaf again. BUT, it was the key fob... replaced the battery and will buy a new case, for without the fob registering the car will not turn over or even think about it.
  7. bisco
    52,871
    the fob is so important on these cars, and a weak link. just give me al old fashioned metal key
