Battery issues with 50% loss after 2 years
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, May 3, 2018.
  1. Sid786
    Sid786 Active Member
    267
    148
    Cherry Hill, NJ
    Recently I have read an article about Leaf losing 50% of battery capacity after 2 years of use.
    Anyone of the early adopters of Prius Prime, are you experiencing loss of capacity on Prius Prime battery, as this car is almost 2 years old since inception.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    The Leaf is a BEV and a different animal compare to a PHEV like the Prime since it can only rely on the battery for use while a PHEV can use the ICE to carry most of the load if the battery is being stressed. The beauty of dual fuels. (y)
    Arctic_White, Andyprius1 and orenji like this.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    my guess-o-meter is at 30 miles after a brutal April, so no degradation here after 17 months
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    5 years with my first plug-in Prius resulted in negligible degradation at most. Though, that was in Minnesota, where extreme heat is not the norm. I would always let the battery-pack rest before recharging too.
    Today was my first day getting over 30 miles per charge this year, 13 months into Prime ownership.
    Arctic_White likes this.
  5. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    50% in 2 years? I think there would be quite an uproar if that were actually true. The articles that I read relate to one study showing 15 to 20% loss in 2 years for the previous Leaf model 30 kWh battery, which if true would be three times faster degradation than the earlier 24 kWh battery. However this is preliminary data which needs to be validated with a larger data pool. The current 40 kWh battery is too new to know if it fares any better than the 30 kWh.
    Either way battery degradation is a topic that is often left out by the EV proponents who like to bash PHEV. Their typical argument is that x percent of drivers have daily commutes that fit within EV range. But they should not be looking at the range of a brand new EV, but the range after 5 years of battery degradation which shrinks the number of people whose daily driving fits within that range. No fun having an EV that when new can get you to and from work, but then after 4 years no longer can make that distance, or can no longer make it to work during the winter only during the summer. Whereas battery degradation on a PHEV has a pretty much trivial effect on overall range.
  6. bisco
    52,878
    no worries, leaf was an anomaly, your prime battery will be solid for many years to come.
  7. Sid786
    267
    148
    Cherry Hill, NJ
    You are correct it was around 35 to 40% loss in capacity after 5 years for leaf 30kwh battery.
    Since2002 likes this.
  8. Sid786
    267
    148
    Cherry Hill, NJ
    In the Lithium-ion world there is a notion that to extend the battery life, you should only recharge to 75% capacity. Do you know if this is true for Prius Prime battery as well. Or should we just charge it to max capacity.
  9. john1701a
    12,840
    5,312
    58
    It is actually in the low 80's, which you can clearly see that is what Prime does...
    Notice on the dashboard that 100% is actually 83% on the aftermarket gauge.
    #9 john1701a, May 4, 2018
  10. Sid786
    267
    148
    Cherry Hill, NJ
    Oh that is absolutely brilliant i.e., Toyota had thought of the battery and only charge till 83% of the max capacity. If true, this just confirms that the Prius Prime battery will last for 10+ years or more without any significant degradation. Thank you for sharing, as now I can charge my Prime to max capacity allowed by Prime.
    Arctic_White and thatoneraccoon like this.
  11. Sid786
    267
    148
    Cherry Hill, NJ
  12. hill
    9,041
    Sid - the original 2011 owners (21kWh battery) in extremely hot areas, such as Arizona, parts of Texas & New Mexico primarily, did not realize the damage that DC quick charging could do, especially immediately after running 50 or 60 miles & then recharging. Heat is the greatest enemy of the plug-in traction pack. So when you run for an hour in high temperature, then couple that with high DC rate of charge which compounds the heat, yes, you can destroy capacity in short order ... & YES - that could be as high as 40% in 2 years. Nissan was pretty quick to change out that less resilient chemistry, & that 1st batch of owners reached a (class action) settlement for Nissan's advertising that misled owners to believe that the packs' capacity would not only run for more years than they would, they had literature that suggested the 2011 model would travel a 100 mile range. Yea, only at 30mph on flat ground, moderate temperature.
    Those are not Dynamics shared by the Prius family vehicles. I highly doubt that Toyota will go air cooled when they finally produce a long range EV in the not too distant future.
  13. hill
    9,041
    The plugin car's "buffer" - it's space at the top of the charge that is best not used. That area is where most of the heat is generated during a charge. All plugins do that to one degree or another. Even with the top in buffer, many manufacturers will go a step further and slow charging as the buffer zone is neared. ChargePoint users can observe that on a graph that their app provides, even where some plugin's L2 charge speed is only 3.6kW's. Conversely, a Tesla will charge @ over 100kW's but throttle down below 5kW's if charging up to its full capacity - even so it's thermal management system is liquid. It's mostly about keeping it cool.
    #12 hill, May 4, 2018
  14. Sid786
    267
    148
    Cherry Hill, NJ
    This is great information i.e., avoid DC re-recharging in hot weather immediately after an EV run. Since Prime is the first Toyota PHEV, so we the Prime owners are first the guinea pig.
  15. bisco
    52,878
    no, prime is the second toyota phev, no pigs necessary, i took care of that for you.:cool:
  16. bisco
    52,878
    you get the benefit of my beta testing.(y)
    srivenkat, alexcue and jerrymildred like this.
  17. hill
    9,041
    Maybe the first air cooled phev . The Volt is the 1st liquid cooled phev iirc
  18. bisco
    52,878
    no, pip is the first air cooled phev. where have you people been the last 6 years?(n)
    Arctic_White and benagi like this.
  19. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Go to the dealer and ask them to fix or replace the battery out of the 10Year Warranty.
  20. Oniki
    Oniki Active Member
    652
    500
    Colorado
    There are at least three good reasons to not compare the LEAF to the Prime in terms of battery degradation:
    1. Toyota is not Nissan
    2. The Prime battery has air cooling, the LEAF has only convection from the case
    3. The Prime battery does not use about 35% of capacity, split between top and bottom
  21. Tideland Prius
    16,683
    Again, you're comparing a BEV to a PHEV. A PHEV uses a much smaller range of the battery than a BEV since it has an engine to supplement range (and power).
    Also, there are different chemistries of li-ion so they're not all the same (even though they use the same name). For example, the Li-Ion battery in the regular Prius is a different composition than the one in the Prime.
    Arctic_White, Andyprius1 and KrPtNk like this.
  22. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    Not to mention the loss of range due to cold weather, traffic, high speed or excessive use of accessories such as AC, wipers, etc.
