Battery level at 30% when i picked up my Prius after car detailing
Discussion in 'Gen 3 Prius Main Forum' started by Roger T, Jul 29, 2016.
  1. Mendel Leisk
    41,463
    We have reg's banning car wash in Vancouver city, but in our outskirt city of Coquitlam no ban as yet.
    Funny thing, I wash ours maybe every two months, using about a tablespoon of liquid car wash detergent in a pail with two liters of water. When I'm done there's at least 1.5 liters remaining in the bucket, which I pour out in the house, into the sanitary sewer system. Very minimal impact I would think, we use more detergents washing the dishes.
  2. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    (the bolded) That's where I'm at as well.
    I'll have to ask my buddy who is a Toyota Master Tech if they ever put the Prii into N for any length of time and if so, why.
    As for the car washes, I never use the auto-pull through ones in my Prius because I generally find the "tracks" to be just high enough as to be a pain with our low ground clearance. That style isn't popular around me anyway, most around here are like a garage. You pull in and stop, and the wash apparatus moves around you while you stay still ie. "touchless."
    I also prefer to wash at home but I have a driveway and hose and no water restrictions so it's easy for me. Not everyone is so lucky.
  3. yeldogt
    yeldogt Active Member
    810
    313
    NE
    All my cars go to the car wash -- Almost all of them are brushless. I normally turn off the AC -- but really .. how is it any different vs driving in heavy rain.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    30% won't trigger a warning.
    But the scenario I found myself in, was far less than 30%.
    Not a big deal, and I blame myself far more than The Prius. I've used a drive-thru Car Wash...a lot since getting this Prius. Never had a problem. My mistake was it WAS a hot day, There was a line to wait (not long, probably 5 minutes or less) and I kept the AC blasting the whole time.
    I've entered my 3rd year of ownership and maybe the reality has just changed. I've never had the HV battery nosedive like that before. But I don't suspect anything was wrong, other than I should of waited with all accessories OFF and the windows rolled down, and left the AC off, until I was done with the car wash.
    Next time I use the dreaded Drive-Thru, I'll pay closer attention.
    I use to believe the risk of getting a low battery message was low...nearly minimal...having experienced it now? I'd say I've changed my opinion and SOC and Accessory usage are definitely factors you need to pay attention to if you get in line to use a drive through car wash.
    Roger T likes this.
  5. Roger T
    Roger T Member
    198
    48
    MA
    I am curious. Do you remember the exact warning message? Was there any audible warning sound?
  6. The Electric Me
    9,083
    5,801
    Sorry, since it has only happened to me once, I don't remember the exact wording. I don't remember an audible tone either, but I was sitting in an operating car wash at the time.
    Roger T likes this.
  7. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Car won't start
    First you would need to get the car to towed to an authorized dealer .... then they test if the battery was damaged or not (possible) then they can charge it I am not aware of anything the user can do. In case the battery or some of the cell were damaged you will have to get a new battery and get is installed ... and yes NOT under warrantly. (You used the car in a way it was NOT supposed to)
  8. szgabor
    994
    175
    Oceanside NY
    NO in neutral it WONT charge I do not suggest to try because you can damage the HV battery !!! When it is in Neutral, ICE is separated from the CVT ("transmission") and the motor/generator MG1 CANNOT restart the engine. I think you were in parked !!!!
  9. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    @Roger T
    Would you be so kind as to state exactly what you are using to measure the % of the SOC you have been quoting in this string?
    I am specifically asking for a name brand of the device you are using. I see numerous references to anywhere from 30% and up in your posts, but have not seen exactly what you are using to measure said percentage.
    Please clarify.
  10. Roger T
    Roger T Member
    198
    48
    MA
    Sure.
    ScanGauge II. I got it from autozone. I mount it on my dashboard at all times. If you want to get it from autozone, check out the gift cards for autozone online from Giftcards Zen etc. It offers steep discount for autozone.
    Toyota/Lexus/Scion Specific : Linear Logic : Home of the ScanGauge
    There is a google doc link on the bottom of this webpage. I used the "State of Charge" gauge.
    I show "State of Charge", "Battery Amps" and "Battery Temp 2 F" in my ScanGauge II all year around. In summer i typically have "Battery Cooling Fan Mode" too. You will be surprised to see how often the Prius limit the use of battery when the battery gets hot in summer (Massachusetts here). Once the BT2 reaches 110 F+ (rough range), the Prius will limit the EV current, regen current etc (from what i read from "Battery Amps", car will be slightly sluggish, and engine will be slightly louder, although i did not notice the sluggishness before i get the ScanGuage ii at all). In winter, i use "Engine Coolant Temperature F", which i don't need in summer because the engine warms up so fast and "Battery Temp 2 F", which you will see how the battery performance goes up when the the BT2 goes up from low temperature, and if the battery goes under 32F, the engine will stay on to avoid using the battery at all, then i would put the air recirculation mode to fresh air mode, the escaped warm air will heat up the battery above 32F quickly and the car would again enter EV mode when I stop at traffic stop.
    The ScanGuage definitely added some fun into the Prius experience. ;)
    #50 Roger T, Aug 5, 2016
    CR94 and dorunron like this.
  11. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Mostly true, partially not true. The engine is not separated mechanically from the transmission in neutral. Therefore MG1 has to spin if the engine is running and the wheels (thus also the ring gear) are stopped. However, both motor-generators are electrically shut off in neutral, so no useful power can be generated to recharge the battery.
    szgabor likes this.
  12. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Right !!!!
  13. Virg
    Virg Junior Member
    28
    Austin Texas
    Why put it in "neutral" instead of "park"? I can understand a neutral setting when going through a car wash, but not otherwise.
  14. Roger T
    Roger T Member
    198
    48
    MA
    I think he actually meant "Park" when he said "Neutral". The car won't recharge itself in neutral.
