battery losing charge whilst driving
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by cruising gal, Jul 6, 2016.
  1. bisco
    52,785
    too soon for brake fluid and coolant. read your maintenance manual from the manufacturer of the vehicle.
    fuel economy maximizer? ru as fast as you can.
    never say the word jiffy, on these forums. if you don't have a local mechanic, shop dealers for tranny fluid replacement.
    if he looked at the cabin air filter, and it was dirty, he could have replaced it with no additional labor.
    Raytheeagle likes this.
  2. cruising gal
    cruising gal Junior Member
    27
    austin tx
    2014 Prius v wagon
    hmm, yes rookie error! I thought the dealership service would be aligned with the manufacturer's recommendations.
    Point taken re: jiffy lube. There is a local chain called Lamb's.
    Would any of the above fluids be dirty and need replacing?
    52,785
    just the tranny, and only because most of the experts here agree that toyota's 'lifetime' terminology is for marketing, and not because there aren't contaminants.
    generally, dealers come up with their own very profitable maintenance schedule. they are independent businesses, with only a superficial connection to toyota.
    if you can find one to do the tranny fluid for under a hundred dollars, that's reasonable. it's a simple 4 qt. drain and refill, with new crush washers on the plugs.
  4. cruising gal
    27
    austin tx
    2014 Prius v wagon
    so, I have looked at the maintenance schedule from Toyota now.
    transmission fluid, brakes lines and hoses and engine coolant were all due to be inspected at 60k miles. I have incomplete service history, the last owner seemed only to have servicing and oil change done at Toyota.
    I looked through up to 110k miles and couldn't find a definitive "replace brake/coolant fluid now".
    How do I know these other 2 fluids don't need topping up or changing? sorry, for all the newbie questions. I really don't want to end up on the side of a highway with my radiator hissing ...... been there.
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Those items are inspected at the 60k service. There is no recommendation to replace those fluids, just check them. Repeat: Toyota does not recommend changing any fluids other than the engine oil.
  6. cruising gal
    27
    austin tx
    2014 Prius v wagon
    The maintenance log says "Inspect and adjust all fluid levels" at 60k then 75k. Maybe I'm confused and perhaps a bit naiive but if the garage has inspected these fluids and say that they need to be "replaced" or "drain and fill", isn't it a bit daft not to do them since they are specifically mentioned in the maintenance log?
    The fuel economy maximiser was suggested because of carbon found on the filter, this is a thorough clean up. Can you point me to anywhere that says this is a waste of money?
  7. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    What the heck is a "fuel economy maximiser"? It could be the procedure of charging a naive customer a high price to do absolutely nothing, in which case you should take bisco's advice to "run as fast as you can" from that shop. At best, it could be a particular shop's marketing term for some combination of procedures that might or might not be needed, e.g., filter replacement, throttle-body cleaning, etc.
  8. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    They are ripping you off. Pay them if you like but its all hogwash. The "maximizer" is the tip-off that these people are crooks.
  9. Air_Boss
    Air_Boss Senior Member
    4,247
    1,195
    New Yawk
    Classic 'Stealership 101' scare tactics. 'Are ya feeling lucky?'
  10. bisco
    52,785
    the best way to get first hand knowledge of dealership practices, is to go to another one, and see how their recommendations vary. then you will know what they are making up, and what is actually necessary.
    if the second dealership recommends the 'fuel baloney maximiser', go for it.
  11. cruising gal
    27
    austin tx
    2014 Prius v wagon
    The fuel maximiser was mentioned due to the carbon deposits found. I've uploaded an image from their website that says a little about what it is. However, you seem to be correct about it being a service that this particular dealership has put together - a google search only comes up with their name.
    In terms of brake fluid and coolant - these are closed systems that should not be leaking fluid - right? That would be the only reason for touching them, if the levels had gone down? I know from previous cars that they only needed these fluids topped up when the cars had considerably more mileage on them. So, just leave be and watch out for any signs of overheating or spongy brakes?
    The transmission fluid is a lubricant and deteriorates - this is why this is to be changed?
    Have I got the above right? Sorry but it's hard to know what to do when on the one hand you have the garage saying "do this" with what seems like good explanations and you guys then telling me to "do that" with not much explaining and plenty of comments about the garage. You may be right but please could I have real hard information/explanations.
    thanks
  12. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The big question is do you think you will get $250 worth of "fuel maximized" improvement? If you are using top tier gasoline (there was a thread posted in another forum yesterday), you should not be generating a lot of carbon buildup. With the egr though, carbon deposits will occur, requiring attention at some point. The feedback has been question this and get another dealers input for comparison. Have you asked the dealer the time involved or what they will be taking Apart to do the service? The more things they touch, the more risk you run of something else going awry. Remember, they are a business and some are only looking to get more money without offering the value for the service provided. iMHO, I would not do the service as you will not get $250 worth of improvement.
  13. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    LOL, that fuel injector cleaning scam is a dealer favorite for ripping people off.
    Don't know what else can be said, but this dealer is a crook. Toyota has recommended service for a reason, either follow it or don't. Unless you are towing trailers, spending a lot of time off-road or some other "heavy use" scenario there's no justification for replacing tranny or coolant fluids. Even then its arguable at 60k.
  14. cruising gal
    27
    austin tx
    2014 Prius v wagon
    Are we reading different maintenance logs? I'm asking this in all seriousness because on the one that I'm looking at (sorry can't post link but it's toyota one for the car) it says "inspect and adjust" the above fluid levels at both 60k and 75k services. My car is at 71k - that's in 2 years - it's a high mileage car. I bought the car a couple of months ago. My own mileage is about 15k a year and I'm a suburban mom making the odd out of town trip.
    I can't find anywhere in the maintenance log where it says "replace ". Only "inspect and adjust". I get that this dealer may be pulling a fast one with that fuel maximiser service, and I get that I should go somewhere else next time. But in the meantime, could anyone point me to something that says it is not necessary to replace these fluids until x mileage.
    Thank you.
  15. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The manual does not say "replace" anywhere for those fluids, so what's the confusion?
    There are some folks who say you should replace to err on the side of caution. But Toyota does not recommend replacing. Why do you think they need to recommend NOT doing something? Look through the maintenance schedules, do you see anywhere where they say replace?
    Actually in a high mileage car the fluids should last a lot longer. Its low mileage cars you need to watch out for - lots of short trips.
  16. cruising gal
    27
    austin tx
    2014 Prius v wagon
    The only place that says specifically "replace transmission fluid" is at the 60k service for special operating conditions (towing etc). Since I don't know whether this applies to the car then I will get that fluid replaced.
    I will go to the local place (lambs) and ask them to take a look at the coolant and brake fluids to see if they think it needs replacing. I won't do the fuel maximiser thing, at least not yet.
    thanks for all your patience as I get to grips with it all.
  17. bisco
    52,785
    the only hard info we can gove you is the manual. you are correct, 'inspect and adjust' means to check the levels and top up as necessary. even though the systems are closed, there is no system that can completely contain fluid, and over time, there may be small amounts needed to top up. if during inspection, a large drop is noticed, it's time to look for a leak.
    regarding the tranny fluid, again, some knowledgable people here have sent it out to blackstone labs for testing. due to the amount of contaminants in the fluid, the lab recommended changing. however, toyota calls it lifetime, and it's really up to you.
    the reason we come to priuschat is for more detailed knowledge and experience, that dealers just don't take the time to do. but there is no scientific consensus here, and we're all left to make decisions ourselves.
    there is one thread you probably should read. it was done by the wife of a certified prius mechanic, back in the day. and while a few of the systems have changed over the years, most still apply. it is called 'what services you need and what you don't'. the members name is 'galaxee' and you can find it in the gen 2 prius forums, in the 'care maintenance and troubleshooting' forum. pinned near the top.
    all the best!(y)
  18. Mendel Leisk
    42,273
    Does it come on every 5000 miles? Then it's really only saying "some" service is due. US oil change interval is 10000 miles or 12 months, whichever comes first. And, with all the intervals being distance or time, the maintenance light could be completely out-of-sync. It's just counting clicks.
    As far as maintenance, what's needed and when, the manuals with all the info are available for download (if they're missing): just google "Toyota Techinfo", click on the "manuals" tab on the first link, fill in your vehicle info.
    Regarding the engine and cabin filters: you're not obligated to change them; you should just check them. If they're in good condition there's no reason to change them. When the engine filter is moderately to heavily grunged I would change it. With the cabin filter in similar condition, I'd be much more inclined to knock the dust off, and hit it with compressed air from the reverse direction. Even a vacuum cleaner that you can reverse the hoses to blow would do the trick.
  19. cruising gal
    27
    austin tx
    2014 Prius v wagon
    Thank you for the link to Galaxee's thread. I read through the first couple of pages with interest.
    I had dinner last night with friends who are long time residents of my city, he went 200 miles away to Houston to avoid using the dealership I went to because they have such a bad reputation for very dodgy sales/service practices.
    If the mods will allow it, maybe I could upload a photo of the service estimate I received? I'd ensure that the name of the dealership wasn't visible. Comments on it would be appreciated.
    The tech said my car was actually in great shape so I think I will get the transmission fluid replaced, check the filters myself . The oil change has been done so I will then leave the car until the next 5k interval and go elsewhere. If anyone has any recommendations for my city (Austin, Tx) I'd appreciate them.
    One last question - do you advise the transmission fluid is done at the dealership or can I go to a local non-dealer garage? I wasn't sure from reading galaxee's post whether it is advisable to go outside toyota for this.
    thank you all so much for your patience and time. I have learned a lot about my car in the process and I really appreciate all your replies.
  20. bisco
    52,785
    yes, you can upload dealership names and statements. they are for public consumption, shame and embarrassment.
    dealership is fine for the tranny fluid, as long as it's a hundred bucks or so.
