battery low?
Discussion in 'Gen 2 Prius Main Forum' started by brin wood, Apr 4, 2014.
  1. brin wood
    brin wood Member
    100
    upstate NY
    My '06 only shows 1 blue bar when I start up. Is this a bad indication as to its' longevity?
    Got me a little worried......126K on the car.
  2. JC91006
    16,935
    8,646
    This depends on how many bars you had when you turned it off. Also it shouldn't happen all the time
    SM-N900P ?
  3. JC91006
    16,935
    8,646
    SM-N900P ?
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    As long as you don't see mad swings of green to red and back in just a couple of minutes you should be Ok. The SOC will vary from time to time.
    You will know when the battery is toast. That is when the dashboard lights up and you get codes like P30XX. I would agree it might be weaker than a new battery but if there are no lights on the dash, the battery is operating within specifications.
    Best of luck to you!
    Ron (dorunron)
  5. bisco
    52,792
    is it the same as when you shut down?
  6. Patrick Wong
    18,210
    6,517
    "My '06 only shows 1 blue bar when I start up. Is this a bad indication as to its' longevity?"
    1. I agree that you should look at the traction battery state of charge gauge when you turn off the car, and then compare to what you see when you start up.
    2. If the bar is actually colored blue, my belief is that there will actually be between 3 to 6 bars appearing on the gauge.
    3. If there really is only one bar, then the color typically will be red (or pink.)
    4. Usually, the only time I will see one red bar is when the air conditioner compressor is running while the Prius is parked.
    5. What is a sure sign of impending battery failure is if you see the state of charge gauge rapidly move from 8 green bars to 1 red bar. And of course, if you also see relevant warnings such as either the hybrid vehicle or traction battery warning icons appear in the upper left corner of the MFD.
  7. OCJeff
    OCJeff Junior Member
    I had an issue once where the car was left with a door partially ajar but the car was also beeping because a door was open. Didn't think much of it after the doors locked with the key fob.
    Next morning the battery was at 2 purple bars. It quickly got back into the blue and eventually green. Ever since then I've kept an eye on it (especially over the weekend when it's not used) and it always is green or high blue (which is where I have left it).
    For me it was a one time issue.
    iPhone ?
  8. brin wood
    brin wood Member
    100
    upstate NY
    It was my mistake; it was down to 1 purple bar, not blue. I recall that when I parked it the night before, it was almost full of blue bars. I drove it about 1/2 mile and it filled up again after 2 miles it was all green, making me feel a whole bunch better. Thanks all for the input.
  9. bisco
    52,792
    pleasure.
  10. brin wood
    brin wood Member
    100
    upstate NY
    Curious world.....I'm in upstate NY, told my daughte in FL about getting a Prius, darned if she went out and got one! Next day her husband bought one too. Both '06's. His is a plug in! Said there were only 4 in FL.
  11. bisco
    52,792
    that's great! fyi, they didn't make a plug in until 2012, so it must be an aftermarket setup.
  12. brin wood
    brin wood Member
    100
    upstate NY
    That's right, previous owner had it made into a plug in. Also had new batts. installed. Quite a deal. My son-in-law is getting 65 mpg commuting to work!
